Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
03-15-2003, 15:31 | #1 (permalink) |
Freak Poster Join Date: Nov 2002 Location: Moscow Age: 50
Member: 17812 Status: Offline Thanks Meter: 3 | How to cleare Nokia Life timer ? Who knows how to cleare Nokia Life timer ? Thanks,before |
The Following User Says Thank You to DoctorV For This Useful Post: |
03-15-2003, 15:47 | #2 (permalink) |
No Life Poster Join Date: Aug 2001 Location: P A K I S T A N _____________ Age: 40
Member: 5932 Status: Offline Thanks Meter: 1,694 | Read eeprom from the phone which have 0 timer... than write eepom to other phone which need to 0 timer...... than update faid, sp and IMEI.. done.. Best Regards, Wahab |
05-27-2003, 08:04 | #8 (permalink) |
Freak Poster Join Date: Aug 2001 Location: RO
Member: 5992 Status: Offline Thanks Meter: 1 | krtko you are 110% right. I can confirm that after cloning eep data you'r phone is not working properly. We tested using calibrated GSM Tester and the phone is fail with succes on all RF test after cloning, i'm sure that energy managment tests also will fail... in most cases TX level is higher than normal and will afect you'r health. L. |
05-27-2003, 08:15 | #9 (permalink) |
Registered User Join Date: Jun 2001 Location: x
Member: 4989 Status: Offline Thanks Meter: 13 | Mr Guciano, some months ago you said you have the adresses where lifetimer is stored, maybe you can share them with us, or in private. I think it's stored on 3 bytes like this: When phone comes new LT is 65535255 and in hex FFFFFF. Am I right ? I too I'm against rewriting eeprom area. If I'm forced to do so, I use Wintesla (with PKD-1) to reset phone to default values, but can't do calibration. Yes indeed, in the most cases, when you rewrite eeprom, tx level is higher, and not good for health. I can reduce power with Wintesla, but this is not a good solution. Best is to have original eeprom. |
05-27-2003, 19:01 | #10 (permalink) |
Member: 5992 Status: Offline Thanks Meter: 1 | I tried to write an sw to do this automaticly but the main problem is the life timer is not stored in an fixed location and the bigest problem is that in the same version memory is allocated dinamic and life timer is changing location after power on/off... until now I did not find an algorithm 100% sure for this and was not an big demand for this sw... so if is required I can change only life timer location after 2-5 tries... maybe another solution is to backup eep calibration data ( after I will find the location ) and save this in an "empty" eep... this can be done if is required I think... yes without tester it's impossible to calibrate TX phone on all levels and specially TX- IQ ( this is realy nasty to calibrate ) ... damage is already done... |
Blackberry timer reset how to clear BYUR timers? | baljitsb | BlackBerry (RIM) | 34 | 02-10-2013 19:18 |
Blackberry timer reset how to clear BYUR timers? | baljitsb | FuriousGold | 3 | 02-05-2010 10:16 |
How to reset smasung life timer ? | kabirhossain | Samsung Flashers, Software, Firmware. | 6 | 12-29-2009 08:52 |
How to flash the life timer of nokia HPs to 0? | coldcar | Nokia Base Band 5 ( BB-5 ) | 2 | 02-20-2008 08:23 |
How to reset the Life timer in 6100, 6610, 7210 and 7250? | kingofhearts | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 03-14-2003 21:38 |
