Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Multimedia
Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications.
Old 09-14-2007, 13:20   #1 (permalink)
Member: 564081
Thumbs up How to Convert DVD/ Video/ Audio to your Mobile Phone
Nowadays Mobile Phone is a common and popular device and more and more people could not live with out them. Every day there comes out many new mobile phones, many advanced Mobile Phone users even don't know how to convert DVD/ video to Mobile Phone and enjoy the video and music on Mobile Phone well.
How to convert DVD/ Video/ Audio to your Mobile Phone will help you customize DVD and video file as you like and get the best conversion results. This guide will show you how to use Daniusoft DVD to Mobile Phone Suite to rip any DVD (protected DVD) and convert all formats video to Mobile Phone: Palm, LG, Nokia, Motorola, Samsung, Pocket PC, Sony Ericsson, etc. in an easiest way and explain how to make special effect Mobile Phone video.
This guide fits for Mobile Phone: Palm, LG, Nokia, Motorola, Samsung, Pocket PC, Sony Ericsson, BlackBerry and other supports MP4, 3GP, AVI, WMV video.
Part one: How to convert DVD/video to Mobile Phone
Part Two: How to make special effect Mobile Phone video
Part three: How to make Mobile Phone ringtone
Part One: How to convert DVD/video to Mobile Phone
1 Download Daniusoft DVD to Mobile Phone Suite, Install and Run it.
2 Run “DVD to Mobile Phone Converter”. Insert your DVD disc into your DVD-Rom. Click “Load DVD” button to add the DVD file. You can also click “Load File” to add DVD/IFO from your hard disk.
3 Open the drop download list to choose the Audio and Subtitle you like, you can also change the output files location.
A regular DVD movie has several titles, by default, this software will merge all the DVD chapters into one video, you can check the click box before the title list to select any DVD clips you want to rip. There are some of them below:
This software supports all popular Mobile Phones: Palm, LG, Nokia, Motorola, Samsung, Pocket PC, Sony Ericsson, BlackBerry. Etc and list all popular model of them which make your convert more comfortable; it also can rip audio from DVD to WMA, MP3, AAC. Just select any format you want.
At last, click “Start” button to start the conversion.
1. Click“Video to Mobile Phone Converter” to load the Daniusoft Video to Mobile Phone Converter. Then click “Add” button to load video files. This software supports batch conversion, so you can add several video clips at one time.
2. The convert video to Mobile Phone is similar with the operation of convert DVD to Mobile Phone.
This video to Mobile phone converter software can join several different video clips into one file, by just check the box “Merge into one file”.
You also click on the “Settings” button to customize the resolution, such as: video bit rate, encoder, frame rate, audio bit rate, channel, etc. This program also lets you create a profile and save it, then you can use different settings for each video clips.
3. After you finish the settings, click on “Start” button to start the conversion.
If you are not satisfied with only convert DVD/ video to your Mobile Phone. Also want to make your own Mobile Phone video by do some special effect to the video. Daniusoft DVD to Mobile Phone Suite could provide you to Crop/ Trim/ Effect the video.
Tip 1: Cut off the black edges of the video to watch in full screen.
1 Crop –Just click on the “Crop” button to cut off the black edge of your DVD movie to let you enjoy your movie on your Mobile Phone in full screen.
Move your mouse cursor to a box on the frame around the video, and drag the frame to crop your video.
NOTE: If you choose the crop option “Cut off top and bottom black edges”, it will automatic to help you adjust the video in full screen in your iPod with the most excellent quality!
2 Trim – As you have selected the clips to convert, here you can trim any segment of your clips to convert video to your mobile phone by click the “Trim” button.
Drag the button under the Preview window to control the start time and end time to select any segment you want.
With this function, you can trim any parts of your video and merge them into a new video which is your own one.
3 Effect- Set the Video Effects: Brightness, Contrast, Saturation and adjust the volume to modulate the effect. All the progress you can see preview clearly.
Part Three How to make Mobile Phone ringtone
As Daniusoft DVD to Mobile Phone Suite not only support any DVD/ video but also support any audio. With this Mobile Phone converter software you may make your own ringtone.
1 Just find you favourite musics whatever on DVD, other video or in a song. Then load them into Daniusoft DVD to Mobile Phone Suite.
2 Use “Trim” function to select the part you like, then convert it to your Mobile Phone ringtone support audio formats. Also, you can join several part of your music and merge them into one file.
Note: you may adjust the volume by “Effect” function.
3 Finally, copy the audio to your phone and set it to be the ringtone.
Old 09-17-2007, 03:56   #2 (permalink)
Member: 516215
Hi
This very good software.I like it. key?
Old 09-17-2007, 07:53   #3 (permalink)
Member: 564081
Talking Thank you.
If you really like it you may use it.
Old 09-17-2007, 08:59   #4 (permalink)
Member: 20069
Thanks Meter: 128
seems prety intresting features inside . i'll try n post results
Old 09-18-2007, 05:23   #5 (permalink)
Member: 590131
Thanks Meter: 37
can i have da key 4 this
Old 09-18-2007, 07:56   #6 (permalink)
mani_satcell's Avatar
Member: 65535
Thanks Meter: 451
pls give me a registration key
Old 09-18-2007, 08:25   #7 (permalink)
Member: 590196
Talking
I tried it .Its convert speed is very pretty .but I don't know whether it can converter several video at one time.
Old 09-18-2007, 12:23   #8 (permalink)
Member: 549452
Thanks Meter: 13
thank you pls give me a registration key
Old 09-19-2007, 03:50   #9 (permalink)
Member: 589432
yes, i tried it ,it could help me convert several video at one time for my n73.
Another question??can i use this to convert video for my frined's N95??i can not see n95 from the list !
Thank you
Old 09-19-2007, 07:13   #10 (permalink)
shoaibk7's Avatar
Member: 145000
Thanks Meter: 20
nice works thanx for sharing
shoaib
Old 09-20-2007, 09:18   #11 (permalink)
Member: 564081
Talking Thank you
Thank you for support.
Also it could convert DVD/ video to MP4, AVI, WMV fits for iPod, iPhone, PSP, Zune.
Old 09-20-2007, 17:43   #12 (permalink)
Member: 558811
Thanks Meter: 34
it is very good but key is not why?
Old 09-21-2007, 09:05   #13 (permalink)
Member: 564081
Talking Look
You may find on its official website.After you tryed it, if you think it is really good to use, it is worth to buy.
Old 09-27-2007, 07:11   #14 (permalink)
Member: 564081
Wink any other?
And other questions about convert video to your phone?
Feel free to post here!
Old 09-27-2007, 08:26   #15 (permalink)
Member: 544383
make super but key plz send the key
How to convert DVD/video to iPod and transfer iPod files to iPod/PC/iTunes joeofer558 Chinese Models & Cloned Phones 0 01-21-2010 08:52
Full Solutions for Your iPhone: How to convert DVD/video, make iPhone ringtone, backu natogeek Motorola ODM 0 09-02-2009 09:47
How to convert DVD, video, limewire and any video to iphone? maysefooters iPhone 2 / iPhone 3G / iPhone 3GS 44 07-19-2009 18:54
Page generated in 0.47128 seconds with 8 queries
