Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Multimedia
Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications.
Old 06-29-2004, 23:56   #1 (permalink)
vilibrook's Avatar
Member: 35101
Question How To Download Mp3 To 6230???
Hello
I Have Nokia 6230 And Usb-data For 6230.
Any Solution About :
1.what Software Is Easy And Better For Nokia 6230?
2. I Have Tried Download Mp3(7mg) Into The Phone(nokia Pc-suite)
And Nothing(write Me--"no Place")
Any Solution,please
Wbr
Old 06-30-2004, 00:26   #2 (permalink)
Member: 48579
Originally Posted by vilibrook
Hello
Any Solution,please
Wbr
You can use MMB 2.0 to upload it , But you can use program to convert mp3 with the small size only 1.7MB/1 .
Old 06-30-2004, 00:40   #3 (permalink)
*A*S*H*'s Avatar
Member: 60098
which program converts mp3's to a smaller size ? thanks
Old 06-30-2004, 00:46   #4 (permalink)
vilibrook's Avatar
Member: 35101
Question @all
THANK YOU M8.
GOOD QUESTION TOO.
ANY BODY,ANY SOLUTION ???
THANKS
WBR
Old 06-30-2004, 01:05   #5 (permalink)
*A*S*H*'s Avatar
Member: 60098
THANK YOU M8.
GOOD QUESTION TOO.
THANKS
WBR
go here i've heard that it's the best software to use...
http://www.forum.nokia.com/main/0,,034-63,00.html
..but you have to register, good luck.
Old 06-30-2004, 01:34   #6 (permalink)
vilibrook's Avatar
Member: 35101
THANKS
I WILL TRY THIS SOFT.
WBR
Old 06-30-2004, 02:43   #7 (permalink)
e64y's Avatar
Member: 30582
or cooledit............
wbr
Old 06-30-2004, 03:46   #8 (permalink)
vilibrook's Avatar
Member: 35101
wbr
GOOOD M8,THANK YOU.
I WILL TRY THIS PROG. TOO
WBR
Old 06-30-2004, 04:45   #9 (permalink)
SH-Usman's Avatar
Member: 48893
Hello
Any Solution,please
Wbr
listen men i 've alot esay to this u just need a MMC CARD R/W (which is too cheap) too trasnfer the vedio or mp3
the most is that it is time saving
Old 06-30-2004, 13:57   #10 (permalink)
Member: 26048
convert mp3 to aac
using nero 6 or dbpower
http://www.dbpoweramp.com/
Also when you upload Mp3 from pc suite. it will store in the Music files folde and the max file sile is 4mb. Then you can move the file to mmc. The best is buy a card reader and copy the mp3 file to the mmc card.
Old 06-30-2004, 22:50   #11 (permalink)
*A*S*H*'s Avatar
Member: 60098
and here's how to install and use it...
No. Audio Manager just converst audio CDs to aac format. Other than this,
it doesn't perform any file conversion.You can edit the tags of the aac files and transfer music files to 3300.
As far as I know, awb is more like a ringtone format than a music format. aac is the next generation music format (mp4).
To convert your music files to aac (yes, aac takes up much less space), go to http://www.dbpoweramp.com/dmc.htm and download
dBpowerAMP Music Converter. After installing the application, go to http://www.dbpoweramp.com/codec-central-mp4.htm and
download the following codecs
mp4 & AAC Decoder
Pystel mp4 Encoder
FAAC mp4 Encoder
AAC Codec (The others are optional, but this ons is required to convert to aac)
AAC >> Mp4 & Mp4 >> AAC Codec
After downloading and installing these, open the music converter and choose the files to convert. Then choose "Advanced
Audio Coding" codec and choose a quality setting. The settings "Radio, Tape, Internet, etc." are variable bit rate options.
You can choose a fixed bit reat as well, but VBR takes up less space. I convert all of my mp3s higher than 96 kbps to
"Tape" bit rate. There is no significant quality change and the size is usually the half of the original mp3 file,
depending on the length and the bitrate of the song.
However, it's best if you try different settings and compare their sound quality and size yourself.
For some reason, some of the songs can't be converted using the AAC codec. In that case, I convert that song to mp4 using
one of the mp4 encoders and after that I use "AAC >> Mp4 & Mp4 >> AAC Codec" to convert them to aac. I'm not making two
conversions, though.
aac and mp4 formats are actually the same, but they have some identification differences and this codec changes the
identification of an mp4 file to an aac file and it only takes a second or so...
Old 07-01-2004, 15:26   #12 (permalink)
Member: 57105
Thumbs up AAC conversion
Hi,
the next good soft for conversion to AAC format is Easy CD-DA Extractor .
Old 07-02-2004, 00:01   #13 (permalink)
vilibrook's Avatar
Member: 35101
GOOD WAY
BUT I HAVN'T THIS DEVICE.
THANK YOU M8.
WBR
Old 07-02-2004, 00:09   #14 (permalink)
vilibrook's Avatar
Member: 35101
Thumbs up To All
Hello
Really Best Solutions
Thanks
Now I Am Testing Thats Programms And When I should Finish,i should Reply The Best Way For Myself To Upload The Mp3 To Nokia 6230.
Thanks Again For Your Solutions .
With Best Regards
download MP3 To Ringtone Gold 5.02 sana_sheikh_2k Nokia Multimedia 2 01-25-2007 06:22
Downloading MP3 to E760 an2niaguhar Samsung Media, Games, Ringtones 0 11-30-2006 03:22
pls..post here how to convert mp3 to wav pls.... here akshay Nokia Multimedia 17 05-12-2006 13:38
Help - how to download mp3 to P910i Salleh Sony Ericsson 1 07-26-2005 13:01
How to transfer MP3 to 7600 (cable need driver) panji_millenium Nokia Multimedia 2 01-21-2004 02:22
Page generated in 0.48260 seconds with 11 queries
