Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
01-08-2005, 21:32 | #1 (permalink) |
Crazy Poster Join Date: Jan 2005 Location: Malaysia Age: 47
Member: 104455 Status: Offline Thanks Meter: 1 | Symbitz.SeeThru.Keyboard.v2.02.UIQ.SymbianOS7 SeeThru Keyboard for Motorola A92x/A1000 The SeeThru Keyboard software from Symbitz allows text input using a radically different virtual keyboard. It is semi-transparent so you can see your application through the keyboard and the keys are much bigger making it easier to use. Key Features: SeeThru - you can see your app. The keyboard is semi-transparent so the whole application display can be seen at the same time as the key legends. This keyboard doesn't stop you from seeing what you are doing. Bigger Keys - easier to use. Each key is much bigger than those of the built in QWERTY pop-up keyboard. The keys are much easier to hit - making for faster typing and fewer mistakes. You can even let your fingers do the typing. Hotkeys - use the side buttons to show only the keyboard or application. WorkThru - you can still use your app. The keyboard shares the central display area with the app but you can still access the app's buttons and other controls by using the WorkThru features. TapThru - draw a short line from where you wish to tap - say to press a button or to position the cursor. GestureThru - hold just for a moment at the beginning of the gesture - say to select text or to move a slider. Hide - Just hide the keyboard to concentrate on a more complex task. Automatic activation - you don't need to tap an icon. This keyboard appears automatically whenever text input is needed (and it automatically disappears again when the task is complete). You don't have to tap an icon to pop it up and it doesn't use up your valuable screen space. VAL Alphabetic - memorable layout. The Vowel Aligned Left (VAL) Alphabetic layout places the vowels AEIOU down the left hand edge with the other letters following alphabetically. This layout is instantly memorable with the vowels acting as mental sign posts. Cursor Navigation - position with accuracy. Sometimes it can prove tricky to place the cursor at just the right place in text to edit or insert. But with cursor navigation you can move with character precision. Completely Capable - all the characters you need. A full set of characters provide letters, numbers, punctuation, accented letters, currency symbols and more. Compatability - for Motorola A920, A925 or A1000 smartphones. |
