Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Multimedia
Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications.
Old 04-06-2004, 03:45   #1 (permalink)
Member: 49174
Midi Tracker 1.0.5
Create polyphonic ring tones for your mobile phone! MIDI Tracker is music editor with ability to import and export songs to MIDI format. Why you should buy melodies when you can simply create them by yourself?
MIDI Tracker is music editor with ability to import and export songs to MIDI format, support of 128 instruments, assigning volume and tracks count, playing and editing notes by PC keyboard. It is easy to create a song from a several patterns without any copy/paste operations.
All in one
MIDI Tracker is continuation of music trackers such as FastTracker and ImpulseTracker. To work with MIDI Tracker you don’t need any additional music equipment, except your sound card. You can play, edit and record notes by pressing keys of PC keyboard.
MIDI music editor
MIDI Tracker uses own file format for loading and saving. However, MIDI Tracker has MIDI import and MIDI export functions to compatibility with other systems. MIDI file size optimized to keep it as small as possible. In addition, you can import FastTracker module (XM file), for example, to convert it to MIDI format.
It is simple
You can play on your keyboard like playing on MIDI keyboard (with 32 keys) and change the octave by pressing single key (keys F1-F8).
Mobile devices
There are several advantages of using MIDI Tracker for music for mobile devices (mobile phones).
Small file size (usual these devices has a very limited memory size)
Easy access to volume control (to make maximum song volume)
Fast music production (you can make 4min song from 1 or 2 patterns)
Using with sound banks.
(.SBK or .SF2 files for Creative Labs sound cards).
MIDI device uses medium quality patches on most sound cards. The reason is to save the memory, which is probably may be required for other tasks. Download a sound bank file from the net and load it into your sound card memory and you will get a better sound and still low resources usage.
Even you prefer other sequencers for mixing and you find some MIDI Tracker functions useful you can use both sequencers using ‘MIDI export’ function.
Functions
We decided to keep the layout as easy to use as possible. Therefore, there are only two switching screens: pattern view and order view (song order). All other functions are accessible from the toolbar, main menu or shortcuts.
Misc. functions
Transpose track, pattern, channel, block up and down by halftone
Enhanced transpose (using song key tone)
Add / remove track
Add / remove channel
MIDI device choice
Choose patch, volume, disable and enable channels (mute, solo) from the toolbar
Playing and inserting notes and chords
Download MIDI Tracker 1.0.5
http://www.newfreeware.com/files/MTInstall.exe
change .txt to .zip
Rock-N-Scroll.1.0.5.BETA.S60V5.SymbianOS9.3.CR@CKED-OPDA dj_hussain89 Nokia Multimedia 0 12-12-2009 08:58
I Need Killer or Crack for HWK_Suite_Setup_v2[1].0.5 webshawk UFS2 + UFS3-Tornadoflasher 36 07-30-2007 17:58
urgent help for HWK_Suite_Setup_v2[1].0.5 roro_manool UFS2 + UFS3-Tornadoflasher 5 05-19-2007 14:32
Page generated in 0.25510 seconds with 12 queries
