Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
10-04-2004, 10:56 | #1 (permalink) |
Junior Member Join Date: Oct 2002
Member: 17025 Status: Offline Thanks Meter: 0 | Problem with MobiMB 2.2 User ID: Adam Tanzil Password: [email protected] I opened MobiMB while I was connected to the Internet, and now it became an unregistered version again. I tried using the LUK patch, it didn't work. I tried to uninstall and reinstall, still won't work. What can I do? Should I reformat my whole PC just for MobiMB? Or is there a way? |
10-04-2004, 11:25 | #2 (permalink) |
Freak Poster Join Date: Jan 2001 Location: 13 00 N, 122 00 E (PH)
Member: 3156 Status: Offline Thanks Meter: 63 | there is a way. . disconnect from the net edit registry and remove mike bradley\mobilemb traces HKEY_LOCAL_MACHINE\Software\Mike Bradley uninstall mobile mb delete this directory: C:\Program Files\Common Files\LogoManager reinstall mobilemb exit program apply patch connect to net again and be happy! |
10-04-2004, 18:18 | #3 (permalink) |
Insane Poster Join Date: Feb 2004 Location: malaysia Age: 47
Member: 52399 Status: Offline Thanks Meter: 0 | Hi d bug, what patch i need to apply?? can Sir send me the patch for me at " [email protected] ". thanks and appreciate Sir wanderfulnight |
10-05-2004, 12:25 | #5 (permalink) |
Junior Member Join Date: Oct 2004
Member: 85088 Status: Offline Thanks Meter: 0 | I need the patch too! Hi there! I've been searching for the patch too, but I haven't been able to find it. Please help me! The MobiMB 2.2 unregistered version doesn't seem to be very useful.... Thanx from Spain! Rache |
10-06-2004, 01:12 | #6 (permalink) |
Insane Poster Join Date: May 2003
Member: 28366 Status: Offline Thanks Meter: 2 | This way for good work of MobiMB 2.2 MobiMB 2.2 for Nokia 6230 (with sw 4.28) 1) Make sure you remove all the older versions of MobiMB Mobile Media Browser. 2) Manually delete the folder "Logomanager" located in C Drive-> Program Files->Common Files. 3) After deleting and removing, please restart your system (Not necessarily). 4) Don't connect on Internet. (No Dial Up please at the time of setup). 5) Steps to remove the entries: 1. Goto "C Drive->Windows->Regedit.exe" 2. Goto "HKEY_CURRENT_USER->Software->Mike Bradley" [you can see underneath "Mike Bradley" MobiMB Mobile Media Browser. Just delete it]. 3. Goto "HKEY_LOCAL_MACHINE->Software->Mike Bradley" [you can see underneath "Mike Bradley" MobiMB Mobile Media Browser. Just delete it] 4. Install MobiMB without internet connection ! Also don't let's to program be connected to the Internet (use firewall) !!! Make sure you are not connecting to the internet before process the install. 1). install the mobimb 2.2 and register with User ID: Adam Tanzil Password: [email protected] 2). copy 4 file from folder: "from demo" LMMPC.exe LMMPCUI.chm LMMPCUI.dll Nokia.ini to C:\Program Files\Common Files\LogoManager and replace original files. 3). now you will have the working version of mobimb 2.2 for Nokia 6230 with SW 4.28 enjoy... Schturman P.S. Full packet you can download from here: http://www.iphone-forum.org/viewtopi...r=asc&start=90 |
10-06-2004, 04:27 | #7 (permalink) |
Member: 3156 Status: Offline Thanks Meter: 63 | any of the above "fix" works, its up to u what to use. patch here: http://202.47.132.18/~hilux/luk.rar |
10-29-2004, 07:43 | #12 (permalink) |
Member: 28366 Status: Offline Thanks Meter: 2 | Yes. you can connect to the Internet. And if you want run MobiMB without disconnect from internet - use firewall !!!, and dont allow to the program (MobiMB) connect to i-net. It's only installation process of MobiMb, you need run WITHOUT internet connection. Good luck |
Big Problem With MobiMB ! | dynamic-gsm | Nokia Multimedia | 5 | 06-12-2007 09:24 |
Problem of MobiMB 1.2.6 & 1.2.7 | JacsonX | Nokia Multimedia | 1 | 12-27-2003 09:34 |
