Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Multimedia
Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications.
Old 06-02-2009, 03:18   #1 (permalink)
Member: 680758
Psiloc Connect v1.18 S60v3
Psiloc Connect allows you to connect to the Internet in a smart and convenient way. By defining the Psiloc Connect access point in any application you prioritize the way that application connects to the Internet. Psiloc Connect will choose the best available WLAN connection, if no WLAN is available, it will connect through the 3G/GSM access point defined in the application, or if you please it will only use WLAN connections to keep you connected.
Its Features:
Speed
Psiloc Connect always makes sure you use the fastest possible Internet connection available.
Save money
Psiloc Connect allows you to save some money, by not using 3G connectivity when WLAN is available.
Auto Switch
Psiloc Connect handles access point switching for you, no more of that tedious tasks.
How It Works:
Psiloc Connect is an application which will get rid of all your access point problems.
Upon installation the application will create a new access point on your phone - Psiloc Connect. Using that access point in any of your applications will let Psiloc Connect handle the connectivity.
It will do so by firstly searching the current surroundings for known WLAN networks, a connection will be made through the best available WLAN. If however, there are no WLANs in your vicinity, Psiloc Connect might use 3G/GSM to connect to the Internet.
http://downloadraid.com/viewtopic.php?f=18&t=2898
Psiloc.irRemote.v1.00.S60v3.SymbianOS9.1.Unsigned. *******-BiNPDA peste19 Nokia Multimedia 135 05-20-2010 15:04
Psiloc Connect v1.4 S60v3 SymbianOS9.1 aapkae Nokia Multimedia 1 07-01-2009 09:39
Psiloc Connect v1.17 S60v3 SymbianOS9.1 aapkae Nokia Multimedia 1 04-20-2009 09:01
Psiloc Connect v1.15 S60v3 SymbianOS9.1 Unsigned-Update[BiNPDA] beeslappa Nokia Multimedia 0 08-21-2008 01:44
Psiloc GSync v1.18 S60v3 SymbianOS9.1 Unsigned Cracked westgds Nokia Multimedia 0 01-22-2008 13:36
Page generated in 0.22468 seconds with 11 queries
