Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
10-30-2007, 06:12 | #1 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 607914 Status: Offline Thanks Meter: 36 | Rock Your Mobile Call Recorder Pro v1.10 -BiNPDA This useful application will let you record incoming and outgoing phone calls. CallRecorder can start recording automatically or ask whether to record a conversation or not - this will depend on the rules you set. How to start: 1. First, you should turn CallRecorder on. To do this, press Options and select Settings command. In Settings dialog you can turn CallRecorder on and set up some options; 2. After that you should set rules for CallRecorder - considering these rules the application will or will not record phone calls; Main view: You can find all recorded phone conversations in the main view of CallRecorder. The following functions are available here: * Play record. You can change the volume with joystick left/right arrows while a record is being played. To change speaker from loud to quiet or vice versa set an option Play volume in Settings dialog to a corresponding value; * Call a contact or a phone number. If the highlighted record has a phone number, you can dial it even without exiting CallRecorder - just press Call button or select this command; * Send via Infrared/Bluetooth/Email/MMS you can send the recorded conversation with the help of this command; * View contact (hot key: '*') displays a dialog with a contact; * Properties (hot key: '5') displays a dialog with record's detailed properties; * Delete (hot key: 'C') deletes marked records; * Delete all (hot key: 'Pen+C'); * Pack deletes all records that don't have a sound file; * Refresh actualizes the list of records. Code: http://rapidshare.com/files/65384491/CallRecorderPro_1.10.rar |
The Following 3 Users Say Thank You to klaklair For This Useful Post: |
Rock Your Mobile Video Converter for Nokia Smartphones v1.2a WinALL Cracked-SyMPDA | DIGITAL BABU | Nokia Multimedia | 7 | 10-28-2008 15:45 |
Warning - Rock Your Mobile - call recorder. | Hi Folks | Easy-Unlocker | 0 | 09-25-2008 15:39 |
Call Recorder Pro 1.10 without beep | ege051 | Nokia Multimedia | 0 | 09-06-2007 08:03 |
!!!!!Rock Your Mobile Ringtone Converter v1.0 work with all mobiles | muhammad irshad | Nokia Multimedia | 1 | 06-26-2007 18:19 |
