Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
02-08-2006, 17:50 | #46 (permalink) | |
Junior Member Join Date: Dec 2005
Member: 207303 Status: Offline Thanks Meter: 2 | mobile cam Quote:
ei bro can u give me a application that my cell works as a cam.. plz give me the full cracked of it coz i just download of it but it a does not work.. plz... my IMUI 355677000475373 give me registration code.... | |
02-08-2006, 19:23 | #48 (permalink) | |
Freak Poster Join Date: Jun 2005 Location: india Age: 48
Member: 156060 Status: Offline Thanks Meter: 9 | nokia 7710 call recorder Quote:
The Following User Says Thank You to sam_lve For This Useful Post: |
02-09-2006, 15:45 | #50 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Central Borneo
Member: 209644 Status: Offline Thanks Meter: 113 | Quote:
Yes, amonev, i think better if ........without passw. Thank bro for yousr advise | |
02-09-2006, 16:02 | #51 (permalink) |
Member: 209644 Status: Offline Thanks Meter: 113 | EMCC.Software.SnapDV.Mobile.v1.00.S60.SymbianOS SnapDV Mobile allows the capture on Nokia Series 60 phones of panoramic scenes, through a single click on the phone. The JPEG images that are captured can then be sent as an MMS. MobiFun.Soft.Phone.Unlock.v1.01.S60v2.SymbianOS.in cl.Keygen Some of us often forget the Lock Code of the phone minutes after the change. It is not such a problem any more. Phone Unlock resets phone’s Lock Code in case you don’t know it. The new code is the Phone Unlock Registration Key. You can first run Phone Unlock on your device and then register the program only after the successful reset of the Lock Code. Note: The application may run up to one hour depending on the phone. support : Series 60 v2.0 Compatible Devices Nokia 3230,6600, 6620, 6630, 6680, N70 Mihaly.Lakics.CallItemising.v1.0.S60.SymbianOS.inc l.Keygen Have you ever wondered about your telephone bill and you did not know when you made phone calls and who you called? It will not happen again because by CallItemising you can know accurately when and how many numbers you called, who you sent SMS to, when and how much data you downloaded from the WAP or the Internet. Moreover, you can see when you had a call and who called you or who you received SMS from. It can be important if you were abroad. You can also check these data for the few last months. How is it possible? Your phone stores information about the services you use. By this software you can make an itemized list about your phone usage and you can easily send this list to your computer in many ways (Infrared, Bluetooth, Email). The list can be saved to a file too, so you have the opportunity to send the created file anywhere by any program or any way you like. Then you can open, edit, print or make statistics about the sent file by the most spreadsheets. Maybe your phone can not normally store a list which is long enough, but by this program you can increase its capability. You can easily clear this log or its part, for example old items in the list. If you are interested in your communication in the last month or between two dates only, CallItemising helps you. Zenobyte.ZenoMorph.v1.03F.S60.SymbianOS.Incl.Keyge n.Patch-BiNPDA ZenoMorph is a fun program which allows you to distort and play around with photos or other images. Fast image warping software for your Series 60 phone ZenoMorph is a fun program which allows you to distort and play around with photos or other images. Amuse friends, colleagues or family by sending an image of a funny face - a mutual acquaintance perhaps. Works well with pets, too. Turn your cat or dog into an alien! Full control over placing control points Animates between normal and warped image Fast response when moving points Load and save images to photoalbum Send via email/bluetooth/IR/MMS Features: Full control over placing control points - works on any photo Animate between normal and morphed images Fast response when moving points Load and save images to photoalbum Send via email/bluetooth/IR/MMS Compatible Devices : Nokia 3650, 3660, 6260, 6600, 6630, 6670, 6680, 6681, N-Gage CimWireless.SMS.Automated.Responder Main functions: Automatically send an SMS reply to the received SMSes or calls. Reply could be default, personal or advised to group. User can define the default reply message. User can define personal reply messages to each person find from Contacts who has GSM number. User can create groups consisting of bunch of persons find from Contacts. User can define different reply message for each group. Other functions: User can view from log to whom and when the automated responses had been send. Everyone, who doesn't belong to group or don't have personal reply message, will be sent default message. When you once had defined a personal message, group or group message you don't have to define it again unless you don't want to do that. SMS Automated Responder stores the personal replies and groups. You can only change the messaging mode of one specific person to change the content of the reply message. The defining of personal reply messages and groups and group reply messages are done when the SMS Automated Responder is in inactivated state. In inactivated state SMS Automated Responder don't reply to any calls or SMSes. When you activate the SMS Automated Responder it activates the reply to any incoming calls and SMSes. SMS Automated Responder is available in English and Finnish language. Last edited by Drug_Store; 03-01-2006 at 19:43. Reason: Getting space... squeezing |
02-09-2006, 17:51 | #53 (permalink) |
Member: 209644 Status: Offline Thanks Meter: 113 | Turbo Msn 1.91 New Features in version 1.9: * Template seteneces: defining your own fequent used sentences and use them easily while chatting without inputting every time, it comes with 5 default sentences in English * Minor fix: send SMS with mobile phone # automatically inserted, (the recipient need to be defined in the contacts book) Version 1.8 is now available: Option to turn on/off online events notification and new message alert seperately Support Swedish/Spanish/Finnish Some bug fixes Check Mobile INT Technology for details. Improvements in Version 1.7: View all the current online/offline contacts better MMC card support, now allow to send any type of file from MMC card Version 1.6 released: Set nicknames for your contacts, make it easier to recognize your buddies regardless of their constant changing display names Sign in with invisible status, (in fact, any status you set before you sign in) Support MMC card, send your files, and set your own sound alert files from your MMC card Allow setting the sound alerts and front page graphics before signing in. Main features added in Version 1.5: File Transfer (send photos, music, documents, etc. to your contacts instantly) Customizable front page (set your own favoriate photo as the front page) Customizable sound alerts (set your own favoriate sound files as alert for new message or online events) Supports Danish and Portuguese UI The main features in Turbo MSN are: * Contacts management: add/remove/block/unblock contact, add/remove group * Complete emoticon support * Support English and simplified Chinese UI * Presence status support * Sound alert for incoming message * Save chat history to file * Support unlimited chat sessions * Instant message with two or more persons * Send SMS/MMS/EMail * Full unicode support Aspicore.GSM.Tracker.2.v2.15.S60.SymbianOS7.Cracke d The product is intended for fleet tracking or personal location tracking. Would you like to... * View the whereabouts of your entire fleet from your desktop? * Know the closest vehicle or technician to the next job site? * Access yesterday's detailed route history for every vehicle in your fleet? With a system based on Aspicore GSM Tracker, you can! Features Cost-effective and efficient tool to track several mobile phones in a remote SQL database. The client program runs in a Series 60 phone, in the foreground or in the background. The program is able to connect to a Bluetooth GPS receiver and transmit the received GPS location data (NMEA-0183) to a central database via GPRS. You don't even need necessarily to have as many GPS receivers as tracked mobile phones, if a lower accuracy suffices and there are only a few places or standard routes you want to have recognised. The location of the mobile phone can also be determined by the network cell id. You can configure the timers and events, which trigger the data send action. The data is sent in a compact UDP datagram, only a little over 100 GPRS bytes per message. This means that the data transfer costs are minimal compared to e.g. SMS. Location tracking system The central database can be a powerful SQL engine, which handles hundreds of mobile tracking targets. (Depending on the tracking frequency and resolution.) The database accumulates position data from the mobile phones being tracked. Each record in the database is identified by the IMEI code of the phone the data belongs to. The location data is collected to an industry standard SQL database. This makes it straightforward to integrate with the rest of your company data systems. If you are not using a GPS receiver, you must first create a mapping from the network cell ID to a geographical location. Unless you get the cell id location lists from your mobile operator, you can collect the data yourself by driving around the places you want to have recognised by the system and have Aspicore GSM Tracker and a Bluetooth GPS to record the GPS coordinates of the network cells. When the system is eventually being used, the mobile will report its network cell information to the system server by using Aspicore GSM Tracker. The server compares the network cell information to the accumulated data and converts it to an estimated geographical location. This way you can track your sales representatives, delivery men, children etc without them needing to carry a GPS receiver with them. Supported : * Nokia 3230, 6260, 6600, 6630, 6670, 6680, 6681, 7610, N70 upported GPS devices Any NMEA-0183 compliant Bluetooth GPS. Tested with * Socket Bluetooth GPS receiver (technically identical to Emtac) * Holux GR-230 Bluetooth GPS * Anycom GP-600 BC79 Bluetooth GPS * TomTom Wireless GPS (similar to Leadtek) * Belkin Bluetooth GPS Receiver (resembles Fortuna Clip-On) * Bluei Wireless GPS Receiver * Falcom NAVI-1 * Pretec BluetoothGPS * Pretec BluetoothGPS Mini * Deluo / Polstar PBT-111 * Deluo BlackBox Bluetooth Receiver * Rikaline GPS-6033 Bluetooth GPS * RoyalTek RST-1000 Bluetooth GPS Receiver 8mobile.Money.Manager.2.v2.00.S60.Java.Retail-SyMPDA News version 2.1.0: * Advanced email setting email, you can configure an SMTP Account to send email. * Manage Monthly or Total Balance. * Insert initial/current balance in Payment management. * Added Clear Month menù in Transaction List. * Added menù to see a defined number of transaction for month. * Fixed some bugs. Main Features: * Manage multiple payments with option to setting limit amout for Payment. * Full Category Manager. * Manage Currencies and Exchange Rates with option to Convert currencies. * Manage Security access with password. * Custom and Monthly Statistics for category, number of transactions and average. * Enables to send custom and monthly reports in Microsoft Excel, Quicken and CSV Format. * Manage columns sorting in Transactions and Payments list. * More faster with better graphics. MobiFun Soft My Moon Calendar v1.0 S60v2 SymbianOS incl.Keygen My Moon Calendar is a full featured moon calendar showing moon phase, age and distance from the Earth for each day. It is ideal for women who are frequently on a diet and who always wonder when is the best time to start it. Each day can be marked as water, fruit or juice fast, which allows you to easily keep track of the diet. You can choose from three skins which will give different appearance of the application. Compatible Devices : Nokia 3230, 6260, 6600, 6630, 6680, 6681, N70 Total.Wireless.Solutions.Astrologer Overview: Astrologer provides you 3 options: Zodiac Signs: Contains typical information for each Zodiac Sign 1.PERSONALITY TRAITS 2.LIKES & DISLIKES 3.WHATs LUCKY: Lucky Numbers, Lucky Colors, Lucky Days 4.IDEAL PARTNERS It answers all your queries regarding: Finance & Business Personality & Mood Profession, Physical Appearance, Love & Romance, Safety Measures, Accessories You should use Numerology: Here you get to know about your Nature, Ruling Planet and Lucky Days, Lucky Colors, Lucky Stones, Lucky Flowers, Lucky Metal & Lucky Numbers it also tells you about the Diseases you are prone to and how to Prevent yourself from them. Today's Forecast: Here you get prediction about how your day is going to be, based on your Zodiac Sign. Last edited by Drug_Store; 03-01-2006 at 19:44. Reason: Getting space... squeezing |
The Following User Says Thank You to Khatulistiwa For This Useful Post: |
02-09-2006, 18:27 | #55 (permalink) |
Member: 209644 Status: Offline Thanks Meter: 113 | Mtvoid.ControlFreak.v2.50.S60.SymbianOS.Cracked-BiNPDA Mtvoid.ControlFreak.v2.50.S60.SymbianOS.Cracked-BiNPDA ControlFreak 2 is the ultimate Bluetooth PC remote control for your Series 60 phone. Owning the ultimate PC remote control for your Series 60 smartphone will change the way you listen to music and use your computer. Enjoy a degree of freedom that you'll never want to give up. ControlFreak enables you to control Winamp and the rest of your computer with your Bluetooth Series 60 phone. It has all of the music and video controls like play, pause, stop, next, previous, fast forward, rewind and volume. Get organised ControlFreak 2 is now even better at controlling music and video thanks to full Winamp Media Library support. If you've never used it, you don't know what you are missing. Forget about messing around picking you music files with a file browser. With ControlFreak 2 you search for tracks by name or browse by artists or albums. ControlFreak even helps keep your music better organised by automatically collecting compilation albums so they are easier to find. Winamp's Media Library also handles videos so sit back, relax and enjoy the show. You can even set ControlFreak to automatically pause the action if your phone rings. Amaze your friends One of the most amazing features of ControlFreak is the spectrum analyser. You can get up to 40 frames per second of real-time spectral analysis of the music your listening to. The spectrum analyser in ControlFreak 2 is powered by our own advanced latency compensation technology that makes sure the spectrum analyser stays synchronised with the music even as you're moving around the room. It adds a new dimension to listening to your favourite tracks. All stars Winamp now let's you rate your music and ControlFreak 2 makes it easier than ever. Just hit the * key on your phone whenever you're listening to a song and give it a rating from 1 to 5 stars. Expand your horizons Since your computer can do a lot more than play music and video, so can ControlFreak 2. Perhaps the most exciting new feature in ControlFreak 2 is Desktop Control. Use it to do almost anything you normally do with your computer but from anywhere in its Bluetooth zone. Show your holiday photos to your family Make presentations to your customers Give inspiring lectures Chat with online friends from bed Check your email from the lounge Retouch your photos in Photoshop (ok maybe that's a bit of a stretch) Bluetooth Wireless Technology ControlFreak uses Bluetooth® wireless technology to connect your phone to your computer giving you the freedom to control your PC from anywhere in its Bluetooth zone. Since Bluetooth is a radio technology, you don't even need to be in the same room to control your PC. Changes in 2.50 Desktop control: - Faster screen updating for smoother panning and zooming - Smoother mouse movement - 16 bit colour support - Customised controls for the active application. Desktop Control now has built in support for: PowerPoint, Windows Media Player, iTunes, BSplayer, VLC media player, PowerDVD and WinDVD Spectrum analyser: - Two new visualisation modes: vertical centred and horizontal New language supported: - Swedish Key Features Full Winamp Media Library support for ultra fast searching and browsing of your entire music collection by artist & album Playlist loading for normal and dynamic playlists Support for non-Latin character sets including right-to-left aligned languages such as Arabic and Hebrew Automatic connection for seamless startup Easy way to rate your music enabling smarter playlists Phone-wide track change popup for keeping you informed in any application Automatic muting, pausing or volume reduction during calls Desktop Control now with full widescreen mode Expanded language support: - English - Finnish - German - Norwegian - Swedish Full music and video play control (play, pause, next, previous, fast forward, rewind, stop and volume) Detailed track info Playlist view Spectrum analyser Requirements : Requires Winamp 2 or 5 Compatible Devices Nokia 3650, 3660, 6260, 6600, 6600, 6630, 6670, 6680, 6681, 7610, 7650, N-Gage, N-Gage QD, N70, N90 |
02-09-2006, 18:44 | #57 (permalink) |
Member: 209644 Status: Offline Thanks Meter: 113 | SBSH.Papyrus.v1.1.S60.os6.os7.os8.Cracked SBSH.Papyrus.v1.1.S60.os6.os7.os8.Cracked Manage your busy life with Papyrus and your Smartphone. Papyrus is a robust time management solution for Smartphone devices. Papyrus offers many smart views, category coloring and icons and powerful tools to manage and keep track of your schedule. This is how your Smartphone is supposed to act! Daily View Today´s events all on your screen Alarm, private, note ,and recurring icons show for all appointments on the daily view View category icons and leading rectangles for each item according to the appointment selected categories. Appointment´s subject text is colored to easily identify item category Optionally set text size to display more data or for better visibility Much better looking display than the phone´s built-in calendar application Custom scroll-bar that matches the look of your Papyrus display List View Full week display all at once Showing one line of each subject for more information display List view style offers a seven day look ahead display with maximum details, icons and category colors Scroll backward and forward by weeks by moving the joystick left and right, and scroll up and down to view days See your status icons for each appointment Create appointments on the current selected date on the list view Grid View Full week grid display with one line subjects Optionally set smaller font size for more data display packed on one screen View mini leading rectangles for each appointment based on the appointment category color Scroll through days and weeks using the mobile phone joy-pad Create appointments on the current selected date on the grid view Monthly View See the entire month on one screen A 20 hour timeline with category colors showing your appointments appear on each day View category icons on each day rectangle on the monthly view All day and anniversary icons on each day rectangle for days that include all day or anniversary events Choose to show a Quick-View at the bottom of the screen that shows the current day´s activities The Quick-View has a larger detailed timeline for that day, with leading rectangles using category colors and much more! Click on any day to switch to the Daily view for the selected day Enhanced View Dialogs Greatly enhanced view dialogs compared to the built-in calendar View dialogs include full recurrence details when viewing recurring appointments Any included notes show in the view dialogs for appointments Scroll through phone numbers on the Subject, Location and Note fields and dial the selected phone number by clicking your joy-pad Enhanced Create/Edit Item Dialogs More intuitive and compact edit dialogs allow you to view more data on one screen Set categories to each appointment and add new categories Attach icons and colors to categories using the category picker dialog The subject, location, and note input fields support full screen control for easier input and reading with large texts Support for many common recurrence patterns allow you to define recurring events directly from your Smartphone More flexibility in setting reminder times, ability to insert custom reminders, and customize of reminder default values within the settings makes Papyrus the most user-configurable Smartphone PIM available Quickly link contacts to appointments using a special "contact picker" dialog Fast insertion of pre-defined My Text subject and location fields that can be customized |
02-10-2006, 23:22 | #60 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Karachi pakistan Age: 45
Member: 191892 Status: Offline Thanks Meter: 29 | if you want smart movie 3.0 mp3 ring tone in 6600 codec then use this link. http://forum.gsmhosting.com/vbb/show....php?p=1581451 i am waiting your reply. |
""New Java Applications,Symbian Application & More"" | saadhome | Java, iOS, Android, Symbian development | 0 | 04-15-2009 20:32 |
Symbian Games 2006 Series 60 Non-3rd Edition | dsfugabanjr | Nokia Multimedia | 38 | 08-01-2007 17:57 |
Symbian Games 2006 Series 60 Non-3rd Edition | dsfugabanjr | Nokia Multimedia | 3 | 11-19-2006 15:00 |
Free Symbian Applications | tha_nox | Nokia Multimedia | 0 | 03-07-2006 11:29 |
Symbian applications,games, java games, ringtones, wallpapers - ALL FREE | armkbdotcom | GSM Mobile Links | 0 | 09-24-2005 21:29 |
