dead gx10i after replace lcds Hi, can anyone help me out i have a gx10i that after replacing the pcb with the lcds on it is now dead the phone worked perfectly with cracked screen but after i relaced the pcb with the lcds its now dead I then put the original pcb back on , and the phone is still dead , Thinking it needed flashed I then bought a serial cable but the phone wont comunicate with the pc , the cable has standard max232 in the plug and 3 wires is this the corect cable and is it likly the phone needs flashed ? iv looked everyware and cant find any info about this could anyone please clear this up for me Tia Plug |
common guys surly someone has the knolage to help me pleez |
In the event of when anycase, such as MAX323... stands (with other manufacturers such like MAXIM which may initially-letters vary) deals it itself about 5V-technique and when when is to read MAX3232..., then is 3V-technique in them. 3V means 3Volt ... only elders mobile phones run still in 5V-technique. Unfortunately will sometimes "elders" cable, the actually for panasonic-phone provided were in circulation brought (plug sees simulant from and fits also all right at the GX10...20). my Cable is from here : http://www.handy-punkt.com/catalog/p...roducts_id=525 It works fine for backup and flashing. |
as i say the cable has a maxim max232 spill the beens on the lcd replacement plug |
try to check the flex connector from the lcd to the mother board if it is soldered well, there three flex connector check verry well b,r sherwin ;) |
Must be mainboard problem... |
so are you guys saying that disconecting the flex ribbon dos not efect the sware on the fone ? i can solder to a very high standard i work with smd ewipment so dont see that being the problem and i would have expected the replacement of the old lcd to have restored the phone to boot ? please clarafy for me please plug |
I'm pretty sure the board with the LCDs on it IS the brains of the fone. The keypad board is the RF side. You may have damaged the ribbon connector, I trust you used anti-static precaution. Try this, to turn on press power button, release then press and hold. I have a fone that requires this for some reason. Everything else works fine. |
i have 3 flex ribbons so that just about discounts that ati static lol , no but iv never found it a problem 4b and i dont where nylon nickers . can some one please confirm that you can split the 2 halfs on these fones without fooking the sware , i heave read elsware that it dose. plz Plug |
Nah I've done it before and both fones worked fine when I put their original halfs back together. Yours must be a very rare event. |
Hello Guys, I am bringing this old problem back. I also have changed the LCD in a GX10i but now the phone is dead even if I put the old cracked lcd in that was powering up before. PLease help any ideas welcome :( |
Here's an idea I had a fone where you had to press the power button twice to make it turn on. Try that. JD |
