08-20-2004, 18:44 | #1 (permalink) |
Junior Member Join Date: Aug 2004 Age: 53
Member: 78551 Status: Offline Thanks Meter: 0 | dead gx10i after replace lcds can anyone help me out i have a gx10i that after replacing the pcb with the lcds on it is now dead the phone worked perfectly with cracked screen but after i relaced the pcb with the lcds its now dead I then put the original pcb back on , and the phone is still dead , Thinking it needed flashed I then bought a serial cable but the phone wont comunicate with the pc , the cable has standard max232 in the plug and 3 wires is this the corect cable and is it likly the phone needs flashed ? iv looked everyware and cant find any info about this could anyone please clear this up for me Tia Plug |
08-23-2004, 12:43 | #3 (permalink) | |
Freak Poster Join Date: Nov 2003 Age: 66
Member: 43978 Status: Offline Thanks Meter: 2 | Quote:
In the event of when anycase, such as MAX323... stands (with other manufacturers such like MAXIM which may initially-letters vary) deals it itself about 5V-technique and when when is to read MAX3232..., then is 3V-technique in them. 3V means 3Volt ... only elders mobile phones run still in 5V-technique. Unfortunately will sometimes "elders" cable, the actually for panasonic-phone provided were in circulation brought (plug sees simulant from and fits also all right at the GX10...20). my Cable is from here : http://www.handy-punkt.com/catalog/p...roducts_id=525 It works fine for backup and flashing. | |
08-24-2004, 03:31 | #7 (permalink) |
Member: 78551 Status: Offline Thanks Meter: 0 | so are you guys saying that disconecting the flex ribbon dos not efect the sware on the fone ? i can solder to a very high standard i work with smd ewipment so dont see that being the problem and i would have expected the replacement of the old lcd to have restored the phone to boot ? please clarafy for me please plug |
08-25-2004, 06:25 | #8 (permalink) |
Junior Member Join Date: Aug 2004 Age: 46
Member: 78183 Status: Offline Thanks Meter: 0 | I'm pretty sure the board with the LCDs on it IS the brains of the fone. The keypad board is the RF side. You may have damaged the ribbon connector, I trust you used anti-static precaution. Try this, to turn on press power button, release then press and hold. I have a fone that requires this for some reason. Everything else works fine. |
08-26-2004, 12:46 | #9 (permalink) |
Member: 78551 Status: Offline Thanks Meter: 0 | i have 3 flex ribbons so that just about discounts that ati static lol , no but iv never found it a problem 4b and i dont where nylon nickers . can some one please confirm that you can split the 2 halfs on these fones without fooking the sware , i heave read elsware that it dose. plz Plug |
06-02-2005, 12:27 | #11 (permalink) |
Freak Poster Join Date: Jun 2001 Location: London Age: 41
Member: 4926 Status: Offline Thanks Meter: 5 | Hello Guys, I am bringing this old problem back. I also have changed the LCD in a GX10i but now the phone is dead even if I put the old cracked lcd in that was powering up before. PLease help any ideas welcome |
Nokia 5310 Camera stuck on standby after replacing LCD | Johnny242 | Nokia Hardware & Hardware Repair | 15 | 06-12-2010 08:20 |
5500 Sport still not working after replacing LCD | woonuts | Nokia Hardware & Hardware Repair | 2 | 07-27-2008 23:34 |
After Replacing LCD (6630) No Display | Omegaxteme | Nokia Hardware & Hardware Repair | 3 | 12-01-2007 06:20 |
5510 keys not working after replacing LCD | roughana | Nokia Hardware & Hardware Repair | 1 | 04-06-2004 07:27 |
BG3_525 No Display after replace LCD | moldovan | BF, BG, TH, BHx Series | 0 | 02-07-2004 12:40 |
