05-13-2005, 02:57 | #1 (permalink) |
Freak Poster Join Date: May 2004 Age: 48
Member: 66359 Status: Offline Thanks Meter: 1 | GX 25 Solution Unlock gx25 with cracked furious install gx25 modem drivers check which com port modem is using select phone model gx15 in furious select correct com port unlock phone screen goes black remove battery for a few seconds then replace screen turns white with xxxx on display -press 1 -press 99 -press TOP RIGHT BUTTON -press 3 (for unlocking) -press 1 (are you sure) -press TOP RIGHT BUTTON (you see .... _FORMAT after 3 sec) -press 3x TOP RIGHT BUTTON after finished unlocking and phone switch OFF switch back on unlocked works 100 percent just unlocked 2 gx25's GOOD LUCK !!! |
gx 25 gone dead | whallor | Sharp | 1 | 07-23-2005 15:21 |
GX 25 unlocker not working for me:( | zoki | Sharp | 9 | 06-07-2005 01:01 |
Were to find flash for Sharp Gx-25 ? | artgsm1 | Sharp | 0 | 04-21-2005 13:30 |
Gx-25 | deYo | Sharp | 30 | 04-13-2005 09:57 |
sharp gx 25 | white van man | FuriouS II | 2 | 12-17-2004 14:28 |
