Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Sharp
Old 08-09-2006, 10:12   #1 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 49
gx10 & gx20 flashing but no power on
sal all
i got 1 gx10 & 1 gx20 ... both of them flashing ok till the end, but still no power on after...
what seems to be the problem ??
i searched the forum and many people sayd i should leave the phone wihtout the battery fore at least 5h...
did that ...also removed the backup battery....still no change
10x in advance !
Old 10-09-2007, 08:59   #2 (permalink)
Member: 10679
Thanks Meter: 34
I have the same with 1 GX20. I don't know what happened to the phone before.
Is there any trick to revive?
Old 10-10-2007, 10:48   #3 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,225
how you flash the phone?
make sure that you have full charged battery and flash it again with Power Supply, if same then plz check its fuse near the battery terminal
Old 10-11-2007, 01:31   #4 (permalink)
Member: 10679
Thanks Meter: 34
Hello, thanks for your reply.
Tha fuse is OK. (0 Ohms)
Battery is fully charged, (checked in another phone) flashing has completed without error.
I was using Platijet soft, tried to flash just program flash, then program + file system, then all 4 (using a dump from the forum) but it is always the same.
Phone flashes OK, but it can't power on.
a-70 take full flash but no power on problem..... sopnil Siemens Hardware Repair Area 10 10-03-2007 18:07
w810 fully flashes but no power on Mobajer SETool2 5 03-19-2007 16:28
c65 flashing but no power on dariozz Siemens Hardware Repair Area 3 02-17-2007 12:35
3210 can flash but no power on trafix Nokia Hardware & Hardware Repair 0 01-23-2003 18:16
3310 can be flashed but no power on bre786 Nokia Hardware & Hardware Repair 2 07-01-2002 09:36
Page generated in 0.32872 seconds with 8 queries
