Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Sharp
Old 05-06-2003, 18:33   #1 (permalink)
Member: 13095
GX10 not Staying on
I had two GX10 with the same problem of not staying on
i managed to fix one by removing the internal battery,
the other one still has the problem
Regards
Old 05-06-2003, 22:51   #2 (permalink)
daz
Member: 19746
Maybe you have'nt took the battery out properly
Old 05-06-2003, 23:49   #3 (permalink)
farrell's Avatar
Location: The only true wisdom is in knowing you know nothing.
Member: 16573
a5hek, try removing internal battery for at least 1minute.
Good Luck,
Jan Farrell
Old 05-07-2003, 14:15   #4 (permalink)
Member: 13095
left the battery out whole night, repalced it next day
, problem still there..............
Battery has been left out for hours.
Any other ideas.
Regards
Ash
Old 05-08-2003, 10:23   #5 (permalink)
Member: 9755
I've got the same problem, first my phone works fine but now it does'nt respond on anything. It wont start up!!
I've checked battery
I disconnected the internal battery for a night!
My opinion is that it is a software problem, not harware!
Does someone have an solution?
Old 05-14-2003, 09:18   #6 (permalink)
Burnt Cobba's Avatar
Member: 11325
was this phone locked and you tried to unlock it ? or just happened sudenly?
pls let us know
thanks
al
Old 05-14-2003, 19:30   #7 (permalink)
Member: 4268
just on voda...never tried to unlock it.
regards
Ash
Old 05-15-2003, 10:49   #8 (permalink)
Product Supporter and selective member Nsspro
Bph&co's Avatar
Member: 1024
Hi,
My experience show that either Hardware or Software can cause this.
Most probably the CPU runs selftests on start up and if any fail the phone can not stay on.
Error on the communication protocol can cause this, during restart to enter Test mode.
Messing with internal busses, or even connecting a probes of equipment with
'bad earth' will cause this problem.
If removing the battery doesn't help then the problem is permanent.
Best Regards
Old 07-05-2003, 13:21   #9 (permalink)
DUSKnenixs's Avatar
Member: 5169
hello all i have the same problem whyle unlocking process, but i read post i opened phone remove baterry for 1 minute and i have my phone live again.
thanks for help
[IMG] code is Off
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
1100 stay on local mode and will not power upw hooi76 Nokia Digital Core Technology 4 ( DCT-4 ) 3 03-10-2005 15:52
3650 does not stay on pagecenter Griffin 14 07-24-2004 16:37
Gx10 Only Stays On When Holding Button alanmar Sharp 13 05-22-2004 18:08
Samsung N100 Stays on just if on button is down! .::AkhavanGSM::. Samsung Hardware Repair Area 4 11-04-2002 08:13
Page generated in 0.36272 seconds with 11 queries
