04-28-2005, 16:50 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 51
Member: 96593 Status: Offline Thanks Meter: 13 | gx25 unlocking problem i checked all comport settings on 2 computers but not enters diag mode |
04-28-2005, 17:54 | #2 (permalink) |
Junior Member Join Date: Apr 2005 Age: 36
Member: 135908 Status: Offline Thanks Meter: 0 | use this software to unlock Hi I had the same problem but then I used the attached software and my phone went to diag mode. choose gx15, comport then unlock...your phone goes all black you have to remove your battery then insert it again then start your phone then it should display only four [****] you should know the rest press 1 enter 33 press upper right button and so on.... i cant remeber the whole number code but you can search this forum for it and you only need the USB cable no need for redbox for this one |
09-27-2005, 18:03 | #5 (permalink) | |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Create a Bluetooth pairing with PC, connect a serial port, and use Furious cracked selecting GX15 and the connected serial port, does the job successfully, no need for any cable or USB drivers at all... Quote:
Samsung Jet S800 Unlock problem | javakiller | Z3X-Team Products | 8 | 05-15-2010 12:14 |
sharp gx25 charging problem | stavros5 | Sharp | 1 | 04-20-2006 17:42 |
sharp gx25 unlock problem | stigor | ThunderStorm Box | 11 | 01-06-2006 00:08 |
sharp gx25 unlock problem | surajrasaq | Redbox | 2 | 10-23-2005 22:17 |
Sharp GX25 UBS problem | atukhi | Sharp | 2 | 04-29-2005 11:47 |
