Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Sharp
Old 11-28-2007, 09:12   #61 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
check the charging jeck
maybe damaged
Old 03-13-2008, 11:55   #62 (permalink)
Member: 724806
Gx29
Hello! Could anyone tell which cable to use for flashing GX29?
I have original Sharp GX29 sync cable and NEC E606 data cable.
The problem is that computer can't see mobile phone if it's connected without battery. And also GX29 flasher doesn't detect mobile phone with or without battery. (GX29 usb drivers are installed)
The Following User Says Thank You to even1024 For This Useful Post:
Old 03-18-2008, 21:56   #63 (permalink)
KHJAMAL's Avatar
Member: 143939
Is there free software to unlock GX29
Old 03-19-2008, 01:37   #64 (permalink)
Member: 104927
check the forum for the links and you will find tutorials too
Old 03-19-2008, 21:31   #65 (permalink)
KHJAMAL's Avatar
Member: 143939
Thanks........................
Old 04-08-2008, 13:07   #66 (permalink)
Member: 371833
<MARQUEE WIDTH="100%" BEHAVIOR="scroll" SCROLLAMOUNT="5" DIRECTION="left"><a href="http://www.glittergraphics.us" target="_blank"><img src="http://i72.photobucket.com/albums/i185/glittergus/alph/17/m.gif" border="0" alt="Myspace Glitter Graphics, MySpace Graphics, Glitter Graphics"></a><a href="http://www.glittergraphics.us" target="_blank"><img src="http://i72.photobucket.com/albums/i185/glittergus/alph/17/a.gif" border="0" alt="Myspace Glitter Graphics, MySpace Graphics, Glitter Graphics"></a><a href="http://www.glittergraphics.us" target="_blank"><img src="http://i72.photobucket.com/albums/i185/glittergus/alph/17/r.gif" border="0" alt="Myspace Glitter Graphics, MySpace Graphics, Glitter Graphics"></a><a href="http://www.glittergraphics.us" target="_blank"><img src="http://i72.photobucket.com/albums/i185/glittergus/alph/17/o.gif" border="0" alt="Myspace Glitter Graphics, MySpace Graphics, Glitter Graphics"></a></MARQUEE>
Old 06-23-2008, 08:36   #67 (permalink)
adonis1279's Avatar
Member: 164332
Hello all
I have unlocked a 200606 gx29 from vodafone spain with those files and with the next proedure. So, here we are:
Software is the Albelektronik team gx17-gx29 flasher
Full flash is here: gx29
and folow the specifications from the atached image. All of you, have to do is flash the phone, without batery, with the files selected, using a NEC E8 cable, just like the specifications from the image.
Reply problems...
thanks..for this usefull thend
Old 06-30-2008, 11:09   #68 (permalink)
.::MD_AKTER::.'s Avatar
Member: 552244
Sonork: 100.1578827
Gx29 flasher needed
Originally Posted by antonio148 View Post
tested today ........work fine
flash file gx29 working 100% ......10x to pfeilmayer and BB-gsm.
Where i can found GX29 Flasher ?
Old 12-12-2008, 16:12   #69 (permalink)
Member: 434177
merci mon cher pour tes info tretre util merci
Old 01-01-2009, 13:45   #70 (permalink)
Member: 935855
Sonork: harry4joy
Originally Posted by Fre3 Crack3r View Post
Here is the flasher U ask for
Pls i want to download this flasher for gx29
Old 01-01-2009, 13:45   #71 (permalink)
Member: 935855
Sonork: harry4joy
it is a sharp GX29 phone
Old 01-01-2009, 13:54   #72 (permalink)
Member: 935855
Sonork: harry4joy
Pls i really need sharp gx29 flasher
Old 01-14-2009, 08:59   #73 (permalink)
yahia ali's Avatar
Member: 206173
gx29 flasher
hello avery body tak this flasher tested and working by me
The Following User Says Thank You to yahia ali For This Useful Post:
Old 03-20-2009, 12:34   #74 (permalink)
yahia ali's Avatar
Member: 206173
gx29 flashing
hello every body can u help me in gx29 200604 flash and thanks in advence
Old 08-09-2009, 04:32   #75 (permalink)
Member: 1092733
Sonork: aadhar
Gx17 Flasher doesn't work with Gx29zwemspa jacuzzi vergelijken
college works painting scam
The Following User Says Thank You to aadhar For This Useful Post:
[IMG] code is Off
sharp gx29 flash ok not power on Formingus Sharp 30 01-21-2009 10:29
sharp gx29 flash ok not power on Formingus Sharp 1 02-20-2007 11:26
I am lookinf for GX29 flash + flasher !! makroud Sharp 13 02-19-2007 13:16
Sharp Gx29 Flash Procedure yoni93320 Sharp 11 02-08-2007 15:14
Page generated in 0.47837 seconds with 12 queries
