10-06-2006, 04:34 | #2 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | 1-Install first gx15 upgrading tool and restart your PC 2-now remove the batterie from your phone,and insert the cable(without batterie sūre) you must have nec cable(when you insert this cable in a alive sharp phone,the phone start charging) 3-If the pc demand the drivers select automatic search for drivers DOWNLOAD GX25 DRIVERS 4-then run gx25 flasher select files PRESS START. 5-If the phone doesn't power on DO THIS: NOTE:-the batterie must full charged for this operation -If this operation doesn't successful done try again for me it works 100/100. 6-press in the same time 0,3,power on,top right key for 10 seconds and press 0 and 1 and 2 and 3 and top right key and 1 (in all these steps the phone stays OFF till you press 1) 7-now the phone is powered ON press 99 and top right key 8-select init file system or something like that (option number 1) wait some minutes till it finish AND HERE'S YOUR PHONE IS ALIVE. NOTE:-after you press 99 and top right key, SELECT OPTION NUMBER 1 (THE FIRST ONE). NOW you must post the results. HERE ARE THE CABLE YOU MUST USE |
10-06-2006, 16:06 | #3 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: dreams
Member: 188445 Status: Offline Thanks Meter: 86 | Quote:
gx25 DEAD after bad unlock ,Help please | mohammed | Sharp | 24 | 04-04-2006 20:43 |
please help me gx25 dead | markLEE | Sharp | 4 | 05-01-2005 17:45 |
Sharp gx25 dead | andrews | Sharp | 0 | 04-07-2005 13:13 |
Gx25 Dead After Unlock | erayturkoglu | Sharp | 3 | 02-28-2005 18:28 |
gx25 dead??? | billyuk009 | Sharp | 1 | 01-10-2005 12:05 |
