08-22-2006, 16:30 | #1 (permalink) |
Moderator Join Date: May 1999 Location: Blagoevgrad, Bulgaria Age: 52
Member: 73 Status: Offline Thanks Meter: 537 | How To Unlock And Not Kill Gx15/17/25/29 1. Connect phone without battery to computer (Use NEC CABLE) 2. If ask for drivers put drivers (for flashing) 3. Start any "signed or unsigned" GX15 flasher. 4. Prepare for DIAG READ - Choose "Upload" - DIAG combo from "None" change to "Choose" - "Select file" and SAVE AS file - To prevent Error 04 do following. When u see USB_DEV.... into combo box with devices then fast click "Start Loading FLASH" button. 5. Diag readed. - Open HexWorkshop and use IMPORT function to import MOT FILE. (NOT INTEL HEX change to Motorola MOT) 6. Press Ctrl-G (Goto) ... into window Goto choose Adres type HEX and option "From begining of file" for adress enter 01FF2000 MIRACLE!!!!!!! Here u will see codes ... DISCONNECT PHONE. PUT TESTCARD INSIDE. TYPE ON KEYBOARD *01763*6371# TO ENABLE MEP MENU. GO TO SETTINGS/SECURITY/MEP LOCKS IF ASK FOR HANDSET CODE TRY 0000 ........................ IF IS CHANGED CAN PLAY WITH FLASHER AND ADRESES TO READ MOORE AND MOORE... FROM 55% AND SEARCH INTO BIG PRODUCED FILE. ........................ GO TO RESPECTIVE LOCK AND ENTYER CODE... vOILA ... PHONE ARE UNLOCKED ... RF SETTINGS ARE OK BATTERY SETTINGS ARE OK ... PHONE IS PHONE... IF NOT SEE CODES ON THIS ADRESS IF RESET DIAG WILL PRODUCE "START NG" |
The Following 2 Users Say Thank You to Victor For This Useful Post: |
08-26-2006, 23:27 | #4 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: Out of Africa
Member: 45476 Status: Offline Thanks Meter: 16 | Quote:
GX15 Flasher by Platijet (search the board) & HexWorkshop (www.hexworkshop.com) | |
08-31-2006, 01:25 | #13 (permalink) |
No Life Poster Join Date: Jun 2003 Location: somewhere Age: 40
Member: 31028 Status: Offline Thanks Meter: 56 | i have tryed with e616 nec cable. it asks for drivers but i hear cable always on and off signal on usb. after installed driver and does not load the driver i think, anyone can post driver? |
08-31-2006, 10:40 | #14 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: Lisbon, Portugal Age: 47
Member: 69293 Status: Offline Thanks Meter: 19 | Quote:
http://forum.gsmhosting.com/vbb/show...&postcount=108 | |
Sharp 550SH How to unlock and what cable to use ?? | chavrotti | Cruiser Suite | 8 | 03-11-2010 10:43 |
How To Unlock And Not Kill Gx15/17/25/29 | caferimm68 | Sharp | 5 | 11-28-2009 04:46 |
Sharp GX15/17/25/29 Software & Flash File by Albelektronik TEAM | ghjk | Sharp | 2 | 06-26-2009 10:46 |
my210x how to unlock and how many logs need | fixed | SAGEM JTAG UNLOCKER | 2 | 08-26-2008 14:08 |
how to unlock and unfreez u700v and e250 | asihel | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 6 | 07-27-2008 00:32 |
