11-17-2009, 14:28 | #1 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 824555 Status: Offline Thanks Meter: 205 | How To Unlock And Not Kill Gx15/17/25/29 HOW TO UNLOCK AND NOT KILL GX15/17/25/29 1. Connect phone without battery to computer (Use NEC CABLE) 2. If ask for drivers put drivers (for flashing) 3. Start any "signed or unsigned" GX15 flasher. 4. Prepare for DIAG READ - Choose "Upload" - DIAG combo from "None" change to "Choose" - "Select file" and SAVE AS file - To prevent Error 04 do following. When u see USB_DEV.... into combo box with devices then fast click "Start Loading FLASH" button. 5. Diag readed. - Open HexWorkshop and use IMPORT function to import MOT FILE. (NOT INTEL HEX change to Motorola MOT) 6. Press Ctrl-G (Goto) ... into window Goto choose Adres type HEX and option "From begining of file" for adress enter 01FF2000 MIRACLE!!!!!!! Here u will see codes ... DISCONNECT PHONE. PUT TESTCARD INSIDE. TYPE ON KEYBOARD *01763*6371# TO ENABLE MEP MENU. GO TO SETTINGS/SECURITY/MEP LOCKS IF ASK FOR HANDSET CODE TRY 0000 ........................ IF IS CHANGED CAN PLAY WITH FLASHER AND ADRESES TO READ MOORE AND MOORE... FROM 55% AND SEARCH INTO BIG PRODUCED FILE. ........................ GO TO RESPECTIVE LOCK AND ENTYER CODE... vOILA ... PHONE ARE UNLOCKED ... RF SETTINGS ARE OK BATTERY SETTINGS ARE OK ... PHONE IS PHONE... IF NOT SEE CODES ON THIS ADRESS IF RESET DIAG WILL PRODUCE "START NG" Thankx Victor..UseFull and Detailed New Trick for Such Sharp Models..... |
The Following User Says Thank You to caferimm68 For This Useful Post: |
11-17-2009, 20:41 | #3 (permalink) |
Freak Poster Join Date: Oct 2008 Location: FRANCE Age: 44
Member: 889369 Status: Offline Sonork: 100.1638354 Thanks Meter: 321 | Thks! More simple and useful: for gx 17/25/29 just unlock with any free gx15/30 unlocker or polar. For gx 15 just write "unlocked diag" file. (20second to unlock or repair bad unlocked phones) B.R. |
11-18-2009, 06:39 | #4 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
thx 4 adv... | |
The Following 2 Users Say Thank You to roney_nexus For This Useful Post: |
11-28-2009, 04:46 | #6 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1171201 Status: Offline Thanks Meter: 0 | please check diag are version i'm pretty much sure that it's v4 this code reading procedure works with phones with older diag versions (v3, etc.) Dear simpa plz tell me how can we check diag version ?That it v3 or v4 Through this coad *01763*6371# can we chick diag version? when enter test mode you'll see a date if diag is 2006 you can kill the phone ================================================== ===================== home equity loans PPI Claim |
Sharp 550SH How to unlock and what cable to use ?? | chavrotti | Cruiser Suite | 8 | 03-11-2010 10:43 |
Sharp GX15/17/25/29 Software & Flash File by Albelektronik TEAM | ghjk | Sharp | 2 | 06-26-2009 10:46 |
my210x how to unlock and how many logs need | fixed | SAGEM JTAG UNLOCKER | 2 | 08-26-2008 14:08 |
how to unlock and unfreez u700v and e250 | asihel | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 6 | 07-27-2008 00:32 |
How To Unlock And Not Kill Gx15/17/25/29 | Victor | Sharp | 37 | 09-21-2007 18:39 |
