Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Sharp
Old 03-13-2006, 13:39   #1 (permalink)
mbcommunication's Avatar
Member: 116918
Sonork: 100.1590386
Problems Unlocking GX20
Have now tried dataone clip with a error message everytime, also tried Movilcom all sharp unlocker but it will not put the phone in DIAG mode and also the same problem with the latest version of NEC Smart tool all software soloutions using COM port to PS2 adaptor and 2 different GX10/20 PS2 adaptors one a battery powered cable and a normal COM cable, please any advice or suggestions will be apprciated.
Old 03-13-2006, 14:21   #2 (permalink)
flashfone's Avatar
Member: 129546
are you using the gx20 cable this looks the same as the gx10 exept the pin outs are diferent
Old 03-13-2006, 15:25   #3 (permalink)
Member: 116918
Sonork: 100.1590386
Am using the GX10 PS2 Cable which i was imformed by the re-seller (cant remember which as it was a while ago i got it) this was compatible with GX10/10i/20 this is the first 20 i have tried so sounds like the re-seller was not truefull when i made this purchase i have 2 of these GX10 PS2 cables would it be possible to modify one of these to work on GX20 and if so how would i go about this.
Thanks so much for your help so far.
Old 03-13-2006, 19:55   #4 (permalink)
Member: 187150
gx10 and gx20 cable are the same, i have unlocked with the same cable gx10, and gx20 without any problem, so try to download a free software, and i hope you do it.
Old 03-13-2006, 22:36   #5 (permalink)
Member: 116918
Sonork: 100.1590386
Ok can someone please clarify things here possibly plainjet or another mod is the GX10 cable the same as the GX20 if not could someone provide instructions on how to modify my existing GX10 PS2 cable. And if they are the same does anyone have any idea what the problem could be as mentioned above have tried with the 2 mentioned free softwares but cant get the handset in DIAG mode using the dataone PS2 cable with a PS2 to COM adaptor i know the adaptor is fine as i have used it with many other PS2 cables fine and the GX10 adaptor works fine on GX10 handsets.
Old 04-08-2006, 00:50   #6 (permalink)
Member: 116918
Sonork: 100.1590386
Any more ideas have had another couple of gx20 all the same as above
Old 04-08-2006, 01:25   #7 (permalink)
needi's Avatar
Member: 18303
Well if the cable is working for GX10....its ok.Just try soft from WWW.V I L A N I.COM.It works....but remember dont plug out the cable until soft finishes unlocking.
Old 04-08-2006, 01:40   #8 (permalink)
Member: 116918
Sonork: 100.1590386
Have tried that soft already same problem the phone just wont get in XXXX mode
Old 04-08-2006, 06:47   #9 (permalink)
Member: 197720
use sharp gx10 cable works with it perfectly and use sharp unlocker by ****** version 3.1 in usr u will be happy
Old 08-20-2006, 14:08   #10 (permalink)
BCcommunication's Avatar
Member: 76456
Sonork: 100.1579869
i did update files sytem my mobile ok
thanx all my friend
Old 08-20-2006, 14:20   #11 (permalink)
mtony969's Avatar
Member: 24552
Works fine gx10 cable and griffin old box
Old 08-20-2006, 14:34   #12 (permalink)
Hamzah2004's Avatar
Member: 50170
thanx all my friend
Happy for you bro but since the info on this thread is very poor i post a complement.
GX20 Cable is the same as GX10 service. here u got the soft using rapidshare.de.
here is the how to:
RUN THE PROGRAM "GX10i+GX20.exe"
1) CONNECT THE CABLE TO THE HANDSET
2) POWER ON THE MOBILE
3) SELECT THE PHONE MODEL
4) PRESS "Conectar" ( DETAILS SHOULD BE READ FROM THE HANDSET )
5) PRESS "Aplicar Selecion"
THE PHONE IS UNLOCKED
NOTE:
USE THIS SOFTWARE AT YOUR OWN RISK
FOR WINDOWS 98,98SE,ME
some people are experiencing some problems with a missing file on their windows system when trying to run GX10i+GX20.exe
looks like this when you try to launch the software
Component MSCOMM32.OCX or one of it's dependencies not correctly registered: a file is missing or invalid.
Solution
You need to register the MSCOMM32.OCX file on your system.
You need to copy the MSCOMM32.OCX from this CD to your windows system32 folder then open a command prompt by going on to start menu all programs accessories then command prompt.
Now in command prompt type REGSVR32 MSCOMM32.OCX and that will register the OCX file.
Now restart your computer and launch the software.
Take care proceeding. Sharp is sensible. remember what NEEDI mentioned...
Peace
Wassalam
Old 08-21-2006, 03:00   #13 (permalink)
Member: 254830
Cool gx 20
hi!used cable gx10 and used software sharp gxx by spunlock .you found this in www.unlockEasy.com.sorry my inglish
Old 08-21-2006, 04:08   #14 (permalink)
Afzaal's Avatar
Member: 128918
My Experience with GX20
GX10 Cable with V.illani Soft 3.1
1000% Okay Unlocking...
Best Regards.
[IMG] code is Off
Problems connecting GX20 using data cable grumpy Sharp 2 08-01-2005 21:24
Problem In GX20 guedes666 Sharp 2 05-12-2005 10:49
Problem with gx20 teerak2uk Sharp 0 06-25-2004 00:15
How to unlock GX20 ???????? Alien-9 Sharp 9 10-06-2003 03:36
Page generated in 0.54261 seconds with 11 queries
