09-20-2005, 16:52 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Tg. Mures, Romania Age: 59
Member: 96525 Status: Offline Thanks Meter: 0 | Sharp GX10i unlock problem I entered Manual Diag mode and i formatted user area. After that phone became SIM locked. I tried to unlock with cable solution, phone doesn't unlcok with none of tested soft. It enters backup mode, but cannot restore. Any idea how to unlock? I tried even with GX15 soft, because in diag mode phone says: GX15 diag version. 2002. 10. 03 v24 I also tried to unlock with SPST for Vodafone Version 1.17 I used function "Default Set" Everything completes OK, but phone still locked. Last edited by janos6662000; 09-20-2005 at 17:31. |
09-22-2005, 08:28 | #3 (permalink) |
Member: 96525 Status: Offline Thanks Meter: 0 | Thank You very much, Kuku, but i still have problems. I had this soft, but doen't connect to my phone. I have USB cable, and i think that soft works only on COM1. Is that right, or can i change the settings to other COM? My USB cable converts to COM4. For trying the soft, i disabled COM1 and COM2 on the motherboard and set the USB cable to convert to COM1. Soft stil doesn't connect to switched on phone. SPST connects, but doesn't unlock my phone. Any ideas? |
09-23-2005, 16:27 | #5 (permalink) | |
Freak Poster Join Date: Aug 2005
Member: 172227 Status: Offline Thanks Meter: 19 | Quote:
09-23-2005, 17:18 | #6 (permalink) |
Super Moderator Join Date: Feb 2005 Location: United Arab Emirates , Dubai Age: 38
Member: 113928 Status: Offline Sonork: 100.111866 Thanks Meter: 1,838 | Hi Here is Sharp GX10 & GX10 i Unlocking Solution Gx10i/Gx10 security code for all who have problems works 1000% full factory reset - clears EVERYTHING Remove SIM 1 Press 0, 3, top right key and Red key together for about 3 secs until a white display is shown. 2 Press 0, 1, 2, 3, top right key, 1, in sequence. The Diagnosis menu should be displayed. 3 Enter 99 and press the top right key. A message should be displayed saying Input Mode No: 4 Enter 1 and press the top right key. The following messages should appear: · EE_FORMAT START · EE_FORMAT OK · EE_INIT(1) START · EE_INIT(1) OK · BBSRAM CLEAR END · FINISHED · PLEASE ANY KEY 5 Wait until all the above messages are displayed and then press the top right key. 6 Press the M key (very important). Message should display Diag Param Saving. 7 Press the red key to power down the phone Again many thanks to ''unlockchips.com' from nokiafree.org - thought I was knackered cos charger connector block after when u insert sim u will see .....invalid sim card so unlock it with. http://forum.gsmhosting.com/vbb/sho...24&postcount=27 br Rocky Last edited by Gsm Lab; 09-23-2005 at 17:28. |
10-06-2005, 01:22 | #7 (permalink) |
Junior Member Join Date: May 2004 Location: Poland, Stara Jabłonna Age: 43
Member: 66841 Status: Offline Thanks Meter: 0 | I need cable drivers USB for gx10i [email protected] |
02-13-2006, 23:09 | #8 (permalink) | |
Insane Poster Join Date: Oct 2002 Location: RO Age: 45
Member: 16830 Status: Offline Thanks Meter: 32 | Quote:
03-24-2006, 16:21 | #9 (permalink) |
Junior Member Join Date: Mar 2006 Age: 49
Member: 248962 Status: Offline Thanks Meter: 0 | hi can anyone give or email me a link for the software i need unlock my sharp gx10i i have a usb to phone and all the links on here will not open this is doin my head in SOMEONE PLZ HELP thanx sezy |
09-18-2006, 15:01 | #10 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: rawalpindi,pakistan.
Member: 155992 Status: Offline Sonork: 1585672 Thanks Meter: 171 | good work bro it really works. thanks. Quote:
11-03-2006, 04:57 | #11 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | I know this is an old thread but, i was forced to write a post to request the soft to unlock invalid sim in gx10, coz i found that all link is dead. But i'll try to search more. Thanks br, s1emens |
SHARP GX10i unlocking problem, HELP !! | pmauricio | Sharp | 1 | 06-08-2006 14:34 |
Sharp GX10i flashing problem - FreaX ? | Patrick | Sharp | 4 | 09-16-2005 14:41 |
sharp gx10i network problem atfer unlock | karamusa | Sharp | 11 | 04-01-2005 11:25 |
sharp gx10i charging problem | karamusa | Sharp | 2 | 04-17-2004 15:57 |
Sharp gx10i unlocking software | stukachu | Wanted Products | 3 | 08-06-2003 15:51 |
