05-29-2005, 14:49 | #7 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Bangladesh
Member: 37349 Status: Offline Sonork: 100.1613413 Thanks Meter: 362 | Quote:
i need ur help for dead gx15.here i given my sonork id:100.79909. when i connect nec usb cable with phone then win98se detect "unknown device".so,if have any way to connect with that phone then pls help me. proxy_gsm | |
05-29-2005, 15:27 | #8 (permalink) | |
Cheater -Don't Deal with him- Join Date: Mar 2004 Location: GERMANY Age: 42
Member: 60523 Status: Offline Thanks Meter: 9 | Quote:
yes MR baboom right u need upgrade tool and usb cable what ever sharp usb or nec without battry or with battry also never mind tested by me for GX15 dead by bad unlock B.r Robish | |
06-01-2005, 12:18 | #9 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: England Age: 59
Member: 94758 Status: Offline Thanks Meter: 3 | gx15 repair by flash Quote:
I have just repaired a dead gx15, I used a stadard gx15 usb cable, connected the phone and flashed it using upgrade tool, now all is fine plus it no longer has the vodafone settings!! Mad4 | |
06-01-2005, 15:06 | #10 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Czech Republic Age: 51
Member: 72981 Status: Offline Thanks Meter: 9 | Thank you sir Robish, your help we helped me, this driver is ok !! work solutions for repair deadh GX15 by bad unlock : ------------------- tested by me 1.6.2005 -------------- Use NEC-USB cable without batery, flash the phone and all be OK Windows XP -------------------------------------------------------- Downloader = www.unlocker.cz/Sharp/gx15_downloader.rar Flash no customized Vodafone lang English/Russian = www.unlocker.cz/Sharp/gx15_flash.rar Drivers = www.unlocker.cz/Sharp/gx15_driver.rar ----------- ok all --------------------------------------- |
06-01-2005, 15:29 | #11 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: at home
Member: 36951 Status: Offline Sonork: 100.63212 Thanks Meter: 6,247 | Quote:
try this: FULL FACTORY RESET. Format complete EEPROM Remove SIM You must activate test mode. Press (at the same time and about 5 seconds until white display is shown) 0, 3, top right and power on keys. Next press 0, 1, 2, 3 and top right keys, in sequence. The Diagnosis menu should be displayed. Enter 99 and press the top right key. A message should be displayed saying "Input Mode No": Next press 1 and top right key to EEPROM format. The following messages should appear (wait about 2 minutes): · EE_FORMAT START · EE_FORMAT OK · EE_INIT(1) START · EE_INIT(1) OK · BBSRAM CLEAR END · FINISHED · PLEASE ANY KEY Wait until all the above messages are displayed and then press the top right key. Press the M key (very important). Message should display "Diag Param Saving". Press red key to power down the phone. Remove and put the battery. | |
The Following User Says Thank You to AndreS For This Useful Post: |
06-02-2005, 14:19 | #13 (permalink) | |
proxy_gsm | |
06-03-2005, 11:04 | #14 (permalink) | |
No Life Poster Join Date: Jun 2004 Age: 45
Member: 69727 Status: Offline Thanks Meter: 49 | Quote:
06-03-2005, 13:37 | #15 (permalink) |
Member: 72981 Status: Offline Thanks Meter: 9 | 1/ Wrong instal driver 2/ Not flashing by sharp usb cable (only for unlocking) for flashing gx15 must be NEC ! usb cables i phone without batery !! |
sharp gx15 dead even flashed with gx15 uppgrading tool | bismed | Sharp | 4 | 11-03-2009 15:12 |
SHARP GX15 dead after Diag MODE using REDBOX... | DrMobile | Redbox | 69 | 04-13-2006 06:42 |
Sharp Gx15 Dead Will Not Come On | TAZMAN | Sharp | 0 | 01-10-2006 23:10 |
Sharp GX15 Dead :( | zackeriney | FuriouS II | 8 | 06-01-2005 16:56 |
Dead Sharp gx15 pls Help.. | Martin1983 | Sharp | 4 | 02-24-2005 19:15 |
