08-03-2005, 19:19 | #5 (permalink) |
Junior Member Join Date: Aug 2005 Age: 46
Member: 167050 Status: Offline Thanks Meter: 0 | Problem HI I TRYED THE LINK YOU GAVE ME. THE SOFTWARE I USED WAS FURIOUS SHARP GX15-GX30-TM100 UNLOCKER AFTER I DID, SADDENLY MY GX15 PHONE SHUT ITSELF OFF AND I CAN'T TURN IT BACK ON, EVEN I PLUG IT IN. NOT WORKING. CAN YOU HELP PLS........... OR ANYONE Last edited by halabira; 08-04-2005 at 22:22. |
08-05-2005, 22:28 | #7 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Retired Unlocker in DZ
Member: 69987 Status: Offline Thanks Meter: 10 | Don't worry Is your phone still look like dead ? Can you see something on the screen? Is your battery well charged ? Can you get it in diag mode? Good luck ! |
08-06-2005, 20:53 | #10 (permalink) |
Member: 69987 Status: Offline Thanks Meter: 10 | When you install gx15 driver, a virtual com port is assigned to the usb used by the phone. You can see which port in windows system properties and select that port number in the inlocking soft. Good luck. |
08-06-2005, 21:03 | #11 (permalink) |
Junior Member Join Date: Jul 2004 Age: 50
Member: 73857 Status: Offline Thanks Meter: 0 | Yes I see the Sharp regisrty icon, I click on that and click 'YES' but get an error, its says - "Cannot import C:\SHARPU~1\Sharp.key: The specified file is not a registry script. You can only import binary registry files from within the registry editor." Why does it say that, what should I do to resolve this, I am running this on WinXP, please help. |
08-06-2005, 21:41 | #12 (permalink) |
Member: 167050 Status: Offline Thanks Meter: 0 | hiya are you using a software called FURIOUS SHARP GX15-GX30-TM100 UNLOCKER virtual com. 1&2 used 3 make sure you take out SIM card before you do it. once phone is cryted, will shut off, if you can't turn it back on ,take battery out and put it back,turn it on and you will see a 4 star **** and you know what to do. thats how i did to my phone hope that will help. |
sharp gx15 dead even flashed with gx15 uppgrading tool | bismed | Sharp | 4 | 11-03-2009 15:12 |
Dead Sharp gx15 pls Help.. | Martin1983 | Sharp | 4 | 02-24-2005 19:15 |
help me sharp gx15 flasher | lyon_service | Sharp | 3 | 12-23-2004 10:34 |
Help unlicking a Sharp GX15 | Knope | Sharp | 0 | 11-26-2004 10:26 |
