11-26-2006, 02:11 | #1 (permalink) |
Crazy Poster Join Date: Feb 2005 Location: PARIS Age: 45
Member: 115771 Status: Offline Thanks Meter: 5 | Sharp Gx29 Flash Procedure YOU NEEDall the files are in forum use searche button please) 1.nec usb data cable 2.GX15-GX17 flasher diag enabled 3.The_GX15_Upgrading_Tool_Installer 4.GX29_repair(files.mot) READY 1.PLUG IN USB CABLE IN SHARP GX29 WITHOUT BATTERY INSTALL THE DRIVERS(THERE ARE IN The_GX15 ading_Tool_Installer DIRECTORY ) 2.RUN TheGX15UpgradingTool.exe 3.RUN GX15 GX17.exe 4.NOW (MAKE A BACKUP OFF YOUR FILES IF YOU THINK IT S NESSESSARY) CHOICE: DOWNLOAD IN FLASH CONTROL PANEL CHOICE: CHOICE IN LOAD FILE PANEL FOR THE 3 FLASH FILES AND SELECT RESPESTIVE FILES (GX29_repair DIRECTORY) 5.MAKE START LOADING FLASH BUTTON 6.POWER ON PHONE BUTTON 2 SEC IF ALL IS OK YOUR GX29 WORK AND UNLOCKED OFFCOURSE TESTED ON 2 PIECES GOOD LUCK(SORRY FOR MY BAD ENGLISH) PS:I DON'T UNDERSTAND WHY "PLATIJET" SAY HIS GX17 FLASHER DON'T WORK WITH GX29 MODEL,,,????????FOR ME WORK FINE BEST REGARDS Last edited by yoni93320; 11-26-2006 at 02:38. |
02-07-2007, 10:36 | #2 (permalink) | |
Junior Member Join Date: Apr 2005 Age: 47
Member: 142041 Status: Offline Thanks Meter: 0 | thanks,yes ,the best choice Quote:
02-07-2007, 22:11 | #4 (permalink) |
No Life Poster Join Date: Aug 2004 Location: ISLAND Age: 53
Member: 80036 Status: Offline Thanks Meter: 25 | 4 me it was a bad idea i have always the 0x06 error when it flash the filesystem if i flash only the program and diag .mot the flash is end succesfully but if i try to flash the filesystem too always this error any clue? btw the phone was "mobile blocked" and i was thinking to flash it to make it work |
02-07-2007, 22:58 | #5 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: Bosnia and Herzegovina
Member: 19493 Status: Offline Sonork: 100.1596420 Thanks Meter: 185 | Quote:
http://forum.gsmhosting.com/vbb/showthread.php?t=355041 B.R. | |
02-08-2007, 02:40 | #6 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Philippines
Member: 42604 Status: Offline Thanks Meter: 187 | Quote:
Sometimes it will power on if plug to USB cable...weird.. | |
sharp gx29 flash ok not power on | Formingus | Sharp | 31 | 06-02-2014 19:16 |
Need sharp gx29 vodafone 2006 05 flash file . | biddut1979 | Sharp | 2 | 11-17-2009 11:57 |
HOW TO REPAIR A DEAD SHARP GX29 or HOW TO FIND THE BEST FILES OF GX29 ??? | Eagle7 | Sharp | 3 | 06-02-2008 20:42 |
Sharp GX29 2007/05 flash files | suspans | Sharp | 3 | 07-21-2007 16:48 |
sharp gx29 flash ok not power on | Formingus | Sharp | 1 | 02-20-2007 12:26 |
