10-04-2008, 18:23 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | Sharp GX15/GX17 NCK Reader How to use it, is easy open platijet flasher, widely available and read DIAG from phone, this way you will have a gx17.bin or gx17.mot file in your pc, now open this app and read the file you have just created, if everything is ok then you should see the NCK code from that phone and then enter it to your phone using accepted simcard and following these steps. 01 - From front screen type *01763*6371# 02 - The handset will reset back to the main screen 03 - Press M button. 04 - Scroll to Settings and press SELECT. 05 - Scroll to Security and press SELECT. 06 - Scroll to MEP locks and press SELECT. 07 - Enter your Handset Code (the default code is 0000) and press OK. 08 - Scroll to Network and press SELECT. 09 - Scroll to Deactivate and press SELECT. 10 - Enter NCK code given by soft and press OK. 11 - Handset should then display DONE and be unlocked. I am just sharing what i found usefull for myself, if you find this is not usefull to you please dont use it, otherwise use Thanks button. PS: I've seen other software to do the same but i couldnt make it work, this one works, at least for me. PS2: This software does not calculates NCK, you have to read DIAG using Platijet Flasher!!!! |
The Following 18 Users Say Thank You to y3kt For This Useful Post: |
10-04-2008, 23:05 | #5 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | does not work on the GX25 v1.0 @y3kt does not work on the GX25, I get: "Invalid File Specified" Please correct this detail, I send the attached file for diagnosing the GX25 to rectify and give us another enhanced version of its software. Another suggestion, Sharp GX29, for example, when reading the NCK, said in its software: ÿÿÿÿÿÿÿÿÿÿÿÿ, I suggest you get a message saying: "already unlocked" br elcapitel |
The Following User Says Thank You to elcapitel For This Useful Post: |
10-05-2008, 17:42 | #6 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | New version: should work better with mot files, please post results if tested, thanks PS: Use thanks button if you think this helps you in some way |
The Following 7 Users Say Thank You to y3kt For This Useful Post: |
10-06-2008, 14:57 | #7 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | jejej, I am at work, when I get home I try version 1.02 and if it works I thank Mr. Y3KT and post the results, thanks for advance. br elcapitel |
10-15-2008, 16:05 | #9 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | it seems that this is only possible with older diag, i have tested newer phones and the position where codes should be is empty, thus we will get "Not locked" message in soft, there is nothing i can do, thanks for trying it, luck |
10-30-2008, 02:54 | #12 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Sharp GX17 version 200602 read code ok Here Prscreen and .mot from rapidshare.com http://rapidshare.com/files/15886401...00602.mot.html br elcapitel Last edited by elcapitel; 10-30-2008 at 03:02. |
11-19-2008, 14:23 | #14 (permalink) |
No Life Poster Join Date: Mar 2003 Location: paris Age: 44
Member: 24284 Status: Offline Thanks Meter: 56 | sorry not work on my gx17 nck yyyyyyyyyy and with last version nck: not locked and it's a locked phone.the same result bin or mot file. i write a unlocked diag mot file and it direct unlocked it. |
11-19-2008, 15:42 | #15 (permalink) | |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Quote:
2006** ? 2007** ? Please specify, I'm doing a similar software, and I need to be tested with different versions that work well and which not. Always respecting that my friend y3kt was not angry br elcapitel | |
sharp gx15 dead even flashed with gx15 uppgrading tool | bismed | Sharp | 4 | 11-03-2009 15:12 |
Where Can I Buy Sharp Gx15-gx17 Usb Cable Flasher Without Battery | guyzo gsm | Sharp | 1 | 04-16-2007 19:34 |
GX15-GX17 Questions | johnny.kill3r | Sharp | 0 | 03-14-2006 11:39 |
I need Chinese languages file for Sharp GZ100 & sharp Gx15 | 2001foobar | Sharp | 0 | 06-15-2005 17:54 |
