sidekick pv200 question from newbie Hi i bought a sidekick pv200 III unlocked on ebay but in Italy where i live i can use it only with wind sim 64K. With other operators like tim or vodafone i cannot find the wireless operator. The question is : is the sidekick not unlocked correctly or is a problem of some sims or somethin else ? Can i unlock again the phone and then maybe i can use other operators ? thanks guys |
you cant unlock side kick. there are two solution buy codes or UNI sim. br |
ok thanks but with codes or universal sim is possible to see other wireless operators or this is a problem of my phone ? thanks |
exists temporaly unlock...but at this moment I haven't more info! I lost it Anybody have? My friend search this temp solution! I know that exists but can't find at moment! |
Here is solution get it Power on the unit: press Menu then go to settings,sim center: Once you're in the sim center, press enable sim lock: enter sim pin - 1234 then press enable then exit at the menu again: Press menu again, as you can see there is new option wich is Unlock sim card: Now go to settings and sim cente again,,press Chnge sim pin then enter old sim pin ( 1234 ) then new sim pin ( 0000 ) as confirm ( 0000 ) then submit: Got ot settings again then network option (wireless on must be checked), Scroll down then scan manually: looking for network,some phones scan slow so repeat scan if fails...: YOu will seee the network provider ,then select press done. That's All BR ABDULATIF ' |
