08-22-2006, 14:00 | #1 (permalink) |
Moderator Join Date: May 1999 Location: Blagoevgrad, Bulgaria Age: 52
Member: 73 Status: Offline Thanks Meter: 537 | True Or Not True .... ;) Are these exe files who are signed "By Platijet" etc .... are YOURS? (OFCOURSE IF WORKS FOR SHARP. BUT IF WORKS FOR SHARP WHY PUT FREE.) (... or not know how to programming?) On simple comparing every middle class user will see ... THEY ARE 1:1 AS ORIGINAL SHARP FILES. ... and everything can edit INI file... and sign "Copyleft (R) ... bla bla bla" |
08-22-2006, 14:18 | #2 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Whats the Point of saying that..... Who DID CopyRight bla bla bla....He helps Us Alot..thats All if u Can COme out with Some thing of ur Own....??? huh!... YEs no i dont think So |
08-22-2006, 14:25 | #3 (permalink) | |
Member: 73 Status: Offline Thanks Meter: 537 | Quote:
also ... NOT ETHIC exe developed by SHARP to be signed... Other: If are moderator (U also) all day to not repeat "My programs"... ... and what we must do ... "SAY OH ***... U ARE BEST" or similar.. | |
08-22-2006, 14:40 | #4 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | you think that you discover the America because you just found that if you edit flash.ini you can change the name of flasher??????? 1.SHARP original flashers needs Wibu key to work.MINE flashers they don't need. 2.GX17 and GX25 flashers are modifyed and patched BY ME.thats why original flash files don't work with my flashers. 3.GX30/GX30i/TM100/TM150/TM200 flashers are original SHARP flashers cracked BY ME and modified to all 4 areas for full flashing. 4.GX29 fullflasher is ALL MADE BY ME and reserved/memory areas calculated BY ME ofcourse. 5.550 and 770 unlocker flasher will released DONLE PROTECTED or i will give it to cruiser or SEtool or someone else. |
08-22-2006, 15:01 | #6 (permalink) |
Member: 26279 Status: Offline Thanks Meter: 274 | when you say that my flashers are "1:1" as SHARP you have to proove it. 1.i remind that sharp flashers needs dongle.mine don't need,so HOW IS "1:1" ???? 2.go on sticky's threads and download SPST.there you will found original flashers.if you are "programer" decode original flashers and compare them with mine's.YOU WILL SEE THAT ARE NOT "1:1" AND THE DIFERENCE IS NOT THE WIBU KEY PROTECTION ONLY. 3.http://forum.gsmhosting.com/vbb/show...8&postcount=26 4.where did you found original GX29 flasher and you are saying that is same with mine??? proove all above or apologise |
08-22-2006, 15:26 | #7 (permalink) |
Member: 73 Status: Offline Thanks Meter: 537 | but INI's are 1:1... infact who is original ... U or SHARP. Also one exe with different ini's works for different phones .... .... general ini format are same... also ... if get ini from spst and put to dir with "Your" flasher ... functions limit ... |
08-22-2006, 15:35 | #10 (permalink) |
Member: 26279 Status: Offline Thanks Meter: 274 | ohh,one more thing: original flash.ini don't need wibu key to open or edit it flashing gx29 with gx15/17 flasher(i remind MADE BY ME) you will read/write 55% of gx29 memory area. |
08-22-2006, 15:42 | #11 (permalink) |
Member: 73 Status: Offline Thanks Meter: 537 | Man ... I know to work with hexcalc... and read also ram/flash/etc without problems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but this is discusion for other time and othwer place. DEFACTO: EXE's are cracked by You but not produced By YOU! |
08-22-2006, 16:09 | #14 (permalink) |
Member: 26279 Status: Offline Thanks Meter: 274 | Why i spend time for stupid threads like that????? anotherone trying to be a hero because he can change the name of an .exe file and he can see memory areas. for your knowlege mr hero : gx29 needs another .exe and memory areas try to find by your self. thread closed. |
Team UB is this true or not? will universalbox tool last only for 5 years... | Unlockemall | Universalbox | 1 | 10-30-2009 08:33 |
Multibox Team Is True Or Not | fany12ro | Multi-Box | 3 | 04-15-2008 10:26 |
how to repair "sp data corrupted" by RPL ?true or not? | tgsm | MT-BOX | 2 | 07-10-2007 11:42 |
New BB5 box true or not? | Kashif Khan | Nokia Base Band 5 ( BB-5 ) | 23 | 02-24-2006 23:19 |
SL45i GRPS TRUE OR NOT | robbiesl42 | x1x to x45/x50 | 4 | 12-12-2002 14:23 |
