C100 power on and after seconds goes off hi all i have problem with my C100 it power on with brown screen and stay about 4 seconds then goes off ....i flashed it and still ths same ..any one can help?? an di have ust 6 cracked but cant connect to it!! |
hi use ust 5.6 and repair sw by c100 flash cabel i hope it will help u regards shahnawaz gondal |
hi put phone in testmode with A300 modified cable then write imei with UST5.6 cracked.phone should still be in test mode and u can use T100 cable or same cable for the imei write!1000000000000000% tested goodluck! |
i repaired it using the flah that repaires all bugs...thanks for all |
hi king bode you sure do by ust 5.6 or6.0 or 7.0 from repair sw by cable x100 sure multi color phone lcd all ok ^ 100% |
I did using the dos flasher come with flash file and using T100 cable |
kingbode can u share the file that repair all bugs ? |
i thibk it exist on the forum u can search for c100 and u will find lnk for it in the forum |
i too need bug repair in c100 can any body help me |
cable t100 by flash phone cable x100 by unlock or eprom or reset ... sure repair sw resualt 100% ok ****************************** |
