Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > VLSI, Conexant, Skyworks and Old Models
VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800.
VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508.
Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208.
Skyworks: A500, C100, C108, C110, P510, P518.
Old 11-27-2001, 06:39   #1 (permalink)
Member: 4234
Post have problem with A300 cable
i wonder is the same cable for A200 and A300<br />while i plug in the cable to A300, the phone show charging?
what's the different between the 2 cable<br />or can i change the pinout form A200 cable to A300?
<br />regards,<br />bobby
Old 11-27-2001, 17:13   #2 (permalink)
gsmcable's Avatar
Member: 7311
Sonork: 100.105990
Thumbs down
different
Old 11-27-2001, 21:14   #3 (permalink)
Member: 3705
Totally different, you can contact Mr.gsmcable,<br />he has professional cables for all Samsung models<br />and the price is 'very' reasonable!<br />GSM Cyber
Old 11-29-2001, 17:17   #4 (permalink)
Member: 6986
Post
To bobby8850
I have the same your problem
B.R
Old 11-29-2001, 20:28   #5 (permalink)
gsmcable's Avatar
Member: 7311
Sonork: 100.105990
THANK GSM Cyber <br />Hi,bobby8850<br />you can goto <a href="http://www.gsmhack.com" target="_blank">gsmhack</a> see the cable<br /> laiycx@21cn.com <br /> gsmcable2001@yahoo.com
Old 11-29-2001, 23:11   #6 (permalink)
evilspell's Avatar
Member: 4160
Post
to gsmcable:<br />the link is dead!!<br />where can i see the cables?<br />do you have also all samsung sw?and the price please?<br />regards
Old 12-01-2001, 14:38   #7 (permalink)
Member: 2709
Post
HI
I HAD BUY A CABLE LABLE A300 WITH EXTERNAL POWER WHICH MADE FROM CHINA. I TRY TO FLASH BY A300 WITH SW AND THE A300 DISPLAY BATTERY SIGN IS FLASHING LIKE IT CHARGING ITSEFT.DOES U CABLE HAVE THE SAME SIGN WHEN PLUG INTO POWER ON A300.IF U PLUG IN THE CABLE THE A300 CANNOT POWER UP.
SO IS THIS CABLE WORK OK?????
HENRY<br /> <img src="confused.gif" border="0">
Old 12-01-2001, 18:22   #8 (permalink)
Member: 3705
Hi Henry,<br />If your cable is bought from China and named<br />'A300' and there has a External power supply<br />adaptor, you should not connect the phone battery,<br />the external supply should be 6-7 volts (inside<br />the cable should has a regular IC), the cable<br />should supply 5V power for flashing the phone.<br />If not OK, then you no need to connect the <br />external supply, just put the battery in phone.<br />The 'Charging' indicator must not displayed,<br />otherwise, you cannot flash the phone.<br />Sometimes the Samsung DOS flasher cannot be work<br />in a fast PC, example: PC with 1Ghz CPU, try<br />another slower PC, such as Pentium or Pentium II<br />machine. (I normally use 486 or Pentium 133 for<br />flashing Samsung phone or operate some original<br />Samsung service software!!!!)<br />And, Mr. gsmcable, I think the Link should be<br /><a href="http://www.gsmhacking.com" target="_blank">www.gsmhacking.com</a><br />GSM Cyber
<FONT COLOR="#ffff00" SIZE="1">[ 01 December 2001 19:26: Message edited by: GSM Cyber ]</font>
Old 12-01-2001, 18:35   #9 (permalink)
Member: 6986
Post
Hi GSM Cyber
I got the same problem ,when I plus the cable to the phone the Charging' indicator displayed.So I can not flash the phone .If you has any idea please help <br /> Thank you inadvand
B.R
Old 12-02-2001, 02:24   #10 (permalink)
gsmcable's Avatar
Member: 7311
Sonork: 100.105990
o,sorry,the link is <a href="http://www.gsmhacking.com/cables/index.html" target="_blank">cable</a>
Old 12-03-2001, 10:24   #11 (permalink)
Member: 6986
Post
Hi GSM cable and Bert
I has try follow your .but when run dd.bat still eror .they display
opening com 1 <br />sending AT to mobile <br />IROM found <br />Requesting IROM version number
After that come back to dos mode
Thank inadvand <br /> B.R
<FONT COLOR="#ffff00" SIZE="1">[ 03 December 2001 11:25: Message edited by: Billgate ]</font>
Old 12-03-2001, 21:44   #12 (permalink)
bluelights's Avatar
Member: 5324
Post
i can supply top quality samsung a300 flashing cables that u use a proper ac adapter to plug in, no using batteries
male me in private<br />i sell them in my shop
regards<br />nick<br />the.one1@virgin.net
[IMG] code is Off
Having problem with nokia cable drivers lahore_mobiles Nokia Base Band 5 ( BB-5 ) 3 10-13-2008 15:50
i have problem with cable 4in1 for cruiser gsm4libya SonyEricsson (USB-Smart) 23 01-31-2006 21:13
@ALL SETOOL customer that have problem with making the cable mobileland LG 7 03-20-2005 04:44
For All who have problems with cables !! Murat Bekar LG 6 03-25-2004 09:59
have a problem with t28 cable NNN Old Ericsson Phones & Sony Phones 1 06-06-2002 19:31
Page generated in 0.36097 seconds with 11 queries
