N500 dead after flash hi! Good N500 came dead after flashing :( I use ToolBox4.3.1 and tested flash file (booth) but phone not power on after flashing! Olso Try Toolbox 5.0 result is same - dead phone and FINAL CHECKSUM ERROR masege. original DOS flasher not fork for me even from purr DOS :( Befor I have flash many N500 without any problem! Pleas help!!! |
Solved by using ToolBox 4.0! After flashing phone work Ok. Strenge.... |
Problems in kabel or konektor... |
eheheh WBR Crew |
2 sem Did You can read?! - Solved by using ToolBox 4.0! |
Better and faster use Dos SW in Dos session for flash. |
Hi, friends. N500 problem is system failure , I dump the files from good N500 phone with new tool box 4.31, same file download to the defective phone after flash,phoen does not power on, I tried with DOS program no response from the phone , I use A200 flashing cable, Pls help how to get back good condition WBR murthy |
use flash files here: http://balance.gsmzone.com.ua/Firmware/Samsung/GSM/UST Flashes/N500/N500_UST002.zip tested by me regards |
BR |
Hi, all Mr. Babak solution 100% working with tool box 4.0 thanks for BABAK |
Mr. Babak solution 100% working , thank you very much BABAK |
Tool Box version 4.1 & 4.32 have Prob with N500 Phone goes to DEAD when flash it with Ver 4.0 Its 100% I also faced this Prob many months ago !!! |
And Thank To Mr.Nasiriyan For His Free Flash Files. |
thank you guys i have been wating for this solution cos i have same problem customer on my neck am so happy thank you all *** bless |
