Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > VLSI, Conexant, Skyworks and Old Models
VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800.
VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508.
Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208.
Skyworks: A500, C100, C108, C110, P510, P518.
Old 09-25-2003, 21:08   #1 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
N500 dead after flash
hi!
Good N500 came dead after flashing I use ToolBox4.3.1 and tested flash file (booth) but phone not power on after flashing!
Olso Try Toolbox 5.0 result is same - dead phone and FINAL CHECKSUM ERROR masege. original DOS flasher not fork for me even from purr DOS
Befor I have flash many N500 without any problem! Pleas help!!!
Old 09-25-2003, 22:15   #2 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
Solved by using ToolBox 4.0! After flashing phone work Ok.
Strenge....
Old 10-01-2003, 22:30   #3 (permalink)
sem
Member: 32704
Problems in kabel or konektor...
Old 10-01-2003, 22:55   #4 (permalink)
Member: 1408
Thanks Meter: 39
eheheh
WBR
Crew
Old 10-02-2003, 09:03   #5 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
2 sem
Did You can read?! - Solved by using ToolBox 4.0!
Old 10-03-2003, 21:31   #6 (permalink)
-=SanSanyc=-'s Avatar
Member: 14640
Better and faster use Dos SW in Dos session for flash.
Old 06-04-2004, 19:24   #7 (permalink)
Member: 16142
Thanks Meter: 21
Hi, friends.
N500 problem is system failure , I dump the files from good N500 phone with new tool box 4.31, same file download to the defective phone after flash,phoen does not power on,
I tried with DOS program no response from the phone , I use A200 flashing cable,
Pls help how to get back good condition
WBR
murthy
Old 06-04-2004, 21:07   #8 (permalink)
Babak's Avatar
Member: 32731
Use ToolBox Ver 4.0 And One Of These Flashes.
http://www.nasiriyan-mobile.com/flas...m/SGH_N500.htm
Old 06-05-2004, 10:29   #9 (permalink)
DeltaGSM's Avatar
Member: 65947
Thanks Meter: 135
Originally Posted by murthy
Hi, friends.
WBR
murthy
use UST 5.6 cracked
use flash files here: http://balance.gsmzone.com.ua/Firmware/Samsung/GSM/UST Flashes/N500/N500_UST002.zip
tested by me
regards
Old 06-05-2004, 10:31   #10 (permalink)
DeltaGSM's Avatar
Member: 65947
Thanks Meter: 135
Hi, friends.
WBR
murthy
olso use T100 flasher cable
Old 06-05-2004, 11:06   #11 (permalink)
Member: 16142
Thanks Meter: 21
Hi, all
Mr. Babak solution 100% working with tool box 4.0
thanks for BABAK
Old 06-05-2004, 11:08   #12 (permalink)
Member: 16142
Thanks Meter: 21
Mr. Babak solution 100% working , thank you very much BABAK
Old 06-05-2004, 19:31   #13 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
Tool Box version 4.1 & 4.32 have Prob with N500
Phone goes to DEAD
when flash it with Ver 4.0
Its 100%
I also faced this Prob many months ago !!!
Old 06-05-2004, 21:21   #14 (permalink)
Babak's Avatar
Member: 32731
And Thank To Mr.Nasiriyan For His Free Flash Files.
Old 06-05-2004, 22:41   #15 (permalink)
btl
btl's Avatar
Member: 50389
Thanks Meter: 36
thank you guys i have been wating for this solution cos i have same problem customer on my neck am so happy thank you all *** bless
[IMG] code is Off
6300 dead after flash 6233 dead after flash mobileZONE MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-27-2010 01:17
>>Samsung N500 Dead After Flashing<< SAYCOMP HWK 3 12-30-2007 14:44
n500 dead after flash monosat UFS2 + UFS3-Tornadoflasher 5 02-26-2006 08:20
N500 Dead after flash unlockmax VLSI, Conexant, Skyworks and Old Models 6 03-21-2005 19:40
Page generated in 0.21871 seconds with 9 queries
