VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800. VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508. Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208. Skyworks: A500, C100, C108, C110, P510, P518. |
12-05-2003, 14:34 | #1 (permalink) |
Insane Poster Join Date: Aug 2003
Member: 37341 Status: Offline Thanks Meter: 0 | plz tell me ur opinion about this , help with unlocking samsung r220,n620 etc. all worked, i unlocked them with this software : Universal Samsung Tool, start the file usteepromwrite.exe, use that one. anyway, i successfully unlocked it everytime i tried, well the problem is : i found a couple of n620's, well i guess both of them reported stolen, so i changed IMEI numbers, isnt that what i supposed to do ?, well, then i tried to unlock them,no luck, i mean it works now, the phone basically from orange, i want to make it simfree, it just doesnt work... when i insert an other simcard from a different network i get the msg : "system failure, contact service provider". yes, i tried the option : " repair system failure", i tried other softwares too, i think the problem is because its stolen, maybe something has changed in the way i have to do this... well i have a couple of questions i want to ask : first question : how do i fix this , im beggin u guys if any of u know how to fix this, plz teach me! second question : i tried tons of sotwares for this task, none worked, execpt one which im not sure how to use, im refering to "Samsung Direct IMEI Writer" - well according to the readme file, i need to start test.exe, and download the ram from the phone, put the phone in test mode and then start IMEI.exe, then change the IMEI, well any of u tried this ? ,well i started test.exe, and started downloading the ram , i noticed it takes time, 30 min at least, so i stopped the progress, any of u can tell me how long it should take, and maybe tell me what u set in the "line setting" in the test program, whats the baud rate should be ?, data bits, stop bits, parity? thanks a lot to all helpers. |
12-09-2003, 12:00 | #2 (permalink) |
No Life Poster Join Date: Jul 2003
Member: 33804 Status: Offline Thanks Meter: 22 | First answer:Rewrite e2prom with Labtool48!!!!!! Second answer:Run test program with test file, after that phone says test mode, and then pls run e2prom tool with e2prom file, for example:*.ust or *.bin...etc... Good luck!!!!!!!! |
this is my third post can any 1 tell me how to use this smt to unlock my401v | observer123 | SMTi | 2 | 07-27-2009 12:12 |
pls tell me which cable will be used to unlock samsung t639 urgent | shahi | UST Pro II | 1 | 10-26-2008 15:47 |
Help with unlocking Samsung SGH-X426 | DarkestHour00 | Samsung Flashers, Software, Firmware. | 1 | 09-15-2008 15:53 |
help with unlocking samsung e250 | alexuk2463 | Phone Unlocking Codes & Maps | 5 | 09-03-2008 13:57 |
Pls help with unlocking Samsung E316 | Piyo | SYSOL Platform | 0 | 09-28-2004 01:16 |
