| VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800. VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508. Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208. Skyworks: A500, C100, C108, C110, P510, P518. |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2003 Location: HUR / R.S Age: 25
Member: 21750 Status: Offline Sonork: 100.62509 Thanks: 4
| R220 system fauilre contact provider no way with UST
i have r220 system fauilre contact provider the imei not the same behind the battery i try to flash the phone and then i write eeprom with universal saamsung tool - main sw v9,9 by vahid shahabi and then i write the imei and no way still the same system fauilre any body can help plz ??/ |
| | #3 (permalink) |
| Moderator ![]() Join Date: Jan 2003 Location: Hong Kong. Age: 33
Member: 19979 Status: Offline Thanks: 8
and also if original UST cannot solve ur problem then SFCP is hardware induced, try cleaning your phone thoroughly....charging jack in particular.... BTW cracked UST does not work, i think u have to write fresh eeprom to ur phone.... u can also remove the E2p and program it externally on pony programmer..
| | #5 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2001 Location: Zagreb, Croatia
Member: 7558 Status: Offline Thanks: 4
UST IS ONE EASY SOFTWARE . NOT FOR FREE .....IN SIDE THIS SOFTWARE YOU CAN FIND MORE EASY STEPS HOW TO REPAIR YOUR PHONE ... BUT THIS STEP CAN BE REPAIRED WITH FREE SOFTWARE ...BUT THIS IS NOT EASY FOR ALL PEOPLES .... IF YOU DON T KNOW NOTHING ...BUY THIS GREAT EASY SOFTWARE ,,,,,,, YOU WILL SAVE YOUR TIME .... BEST REGARDS |
| | #6 (permalink) |
| Moderator ![]() Join Date: Jul 2002
Member: 13808 Status: Offline Thanks: 0
I agree totally with G$M solution, the cost of UST is not too much for someone to consider the cracked version , when you consider the vast model of Samsung supported and MORE IMPORTANTLY the excellent support by VSH-GSM. Dont forget, its very easy to use too. |
| | #7 (permalink) | |
| Super Moderator ![]() Join Date: Aug 2001 Location: P A K I S T A N ___________________ ___Wahab_ul_Haq___ ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ Age: 26
Member: 5932 Status: Offline Thanks: 36
| Re: R220 system fauilre contact provider no way with UST Quote:
Your phone must have Hardware problem.. Just resold your phones eeprom correctly. Best Regards, Wahab | |
| | #8 (permalink) |
| Moderator ![]() Join Date: Nov 2002 Location: OGM Age: 29
Member: 17689 Status: Offline Sonork: 100.72392 Thanks: 17
no way i had tested R220 sys failure with ust its working 1000% just clean the charging jack n heat the Eeprom ic very gently after that try it with ust or with toolbox nokia Unlocker solution both should work!!! |
| | #9 (permalink) | |
| Quote:
| | #10 (permalink) | |
| Quote:
| | #11 (permalink) |
no way guys i try all this selution and the same nothing repair i try with T100 and R220 and still the proplem
| | #12 (permalink) |
listen i will tell u what do do.... remove the charging jack and put a new one..... only solder 4 pins that relate to battery...for other pins dont solder them and instead put some paper or a clean piece of plastic so that they do not touch the contacts.... now power on the phone and see SFCP will be removed..... Syed |
| | #14 (permalink) | |
| Quote:
you say.."clean the charging jack" i say ..."change the charging jack". thank you ... WBR Syed | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
