Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > VLSI, Conexant, Skyworks and Old Models
VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800.
VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508.
Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208.
Skyworks: A500, C100, C108, C110, P510, P518.
Old 01-21-2004, 20:30   #1 (permalink)
Member: 48437
Samsung T100 help
I turn phone on and keep getting
system failure contact provider
i understand is the firm ware needs flashing i have a cable but dont no which software to use and were to get the flash file
correct me if out is rong some one help if can cheers group
Old 01-27-2004, 18:10   #2 (permalink)
Babak's Avatar
Member: 32731
Hi
Almost System Failure Is EEprom Damaged (Hardware Or Software).
First Try To Repaire The Software.
Read Old Post .
Goodluck.
Old 01-28-2004, 14:21   #3 (permalink)
unlockmax's Avatar
Member: 30174
use USt 5.6 crack
If it hardware damadge u must change Eeprom
Old 01-28-2004, 15:27   #4 (permalink)
Member: 48437
Originally Posted by unlockmax
use USt 5.6 crack
try but it cant read the phone, says no phone conected and useing a t100 orignal cable cable ok has unlocked a samsung c100 with it, thanks you for your help guy's but tryd and now jumpt on the phone it p*** me off, lol
Old 01-28-2004, 15:44   #5 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
check/clean charger connector,remove v208;v209 from board
Old 01-28-2004, 17:02   #6 (permalink)
Member: 48437
cant do out now m8 i jumped on it
Old 01-29-2004, 10:13   #7 (permalink)
unlockmax's Avatar
Member: 30174
My friend t100 cable cant unlock C 100
Check connection.
Old 01-29-2004, 11:29   #8 (permalink)
Member: 48437
Check connection.
sorry your rong , i used a a300 clip to put in test mode and then unplug clip and put in a t100 cable and unlocked the c100, if you look around the forums thats were i found it and i tryd and it works
Old 01-29-2004, 11:47   #9 (permalink)
Member: 48437
http://nokiafree.org/forums/t48194/h...locking/s.html
for thous who want to unlock a samsung c100 follow ling and read, it works 100% all u need is a t100 cable and a A300 Clip and software
[IMG] code is Off
Samsung T100 Help... lau1983 VLSI, Conexant, Skyworks and Old Models 0 05-27-2006 04:28
samsung t100 problem please help? chaos1975 VLSI, Conexant, Skyworks and Old Models 1 07-06-2003 10:40
Is my Samsung T100 unlocked?? please help skintbrassic VLSI, Conexant, Skyworks and Old Models 2 04-10-2003 01:08
Samsung T100 blinking in keypad help please Victor the VLSI, Conexant, Skyworks and Old Models 0 12-08-2002 04:48
Samsung T100 Imel Change Help!!! multiproducts VLSI, Conexant, Skyworks and Old Models 0 11-22-2002 12:29
Page generated in 0.36379 seconds with 11 queries
