Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900. |
04-11-2004, 13:04 | #1 (permalink) |
Registered User Join Date: Oct 2003 Location: Vietnam Age: 47
Member: 40808 Status: Offline Thanks Meter: 10 | E700 and V200 camera problem, need help!!!! Regard, |
04-12-2004, 07:50 | #2 (permalink) |
Freak Poster Join Date: Feb 2002 Location: Palestine Age: 61
Member: 9763 Status: Offline Sonork: 100.1655983 Thanks Meter: 2 | Hi Guys, I'v also problem with E700 camera, when press key to Take photos got next warning message " Preview erroe ". can u help please ? Regards Laser |
04-12-2004, 08:25 | #4 (permalink) | |
Member: 9763 Status: Offline Sonork: 100.1655983 Thanks Meter: 2 | Quote:
Hi TONYTONY, what LC cable can u explain please ? Regards Laser | |
04-12-2004, 15:04 | #5 (permalink) |
Member: 9763 Status: Offline Sonork: 100.1655983 Thanks Meter: 2 | Hi TONYTONY, Yes it works 100%, I fix it & camera now working , thank you so much !! it's LC problem cable that come from screen to camera . Regards Laser |
04-12-2004, 15:08 | #6 (permalink) |
Member: 9763 Status: Offline Sonork: 100.1655983 Thanks Meter: 2 | [QUOTE=Laser]Hi TONYTONY, Yes it works 100%, I fix it & camera now working , thank you so much !! it's LC problem cable that come from screen to camera . Regards Laser Hi taihv did u try it ? Regards Laser |
04-12-2004, 15:51 | #7 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: Novi Sad, Serbia Age: 44
Member: 17193 Status: Offline Thanks Meter: 16 | Quote:
"Disconnect IrDA" in v200 is pure SW error... | |
04-13-2004, 10:31 | #8 (permalink) |
Member: 40808 Status: Offline Thanks Meter: 10 | @Laser I'd try it, but with my E700, the problem is the bad connector! Thank for your reply! @GSM electronic I flashed it but can not solve problem! Can u tell me how to fix it? The error message is: Quitar cable de datos de IrDA! Thanx! Regard |
04-13-2004, 11:51 | #9 (permalink) |
Member: 17193 Status: Offline Thanks Meter: 16 | Have You tried FULL flashing? It might help... Next time do not expect someone else to use the search button instead of You... Links: http://forum.gsmhosting.com/vbb/showthread.php?t=131466 http://forum.gsmhosting.com/vbb/showthread.php?t=118875 |
04-21-2004, 12:38 | #12 (permalink) |
Member: 17193 Status: Offline Thanks Meter: 16 | @taihv It's sw problem 101%, as I told You. Check the second link. It'll fix your v200 but It'll transform it to v205. Basically the same, but You'll loose camera zoom. br |
04-21-2004, 12:43 | #13 (permalink) |
Member: 40808 Status: Offline Thanks Meter: 10 | Hmm! I will try again. Thank for ur reply! Another question: my V200 cannot power on with main LCD, but without it everything OK, have you got any solution? RG |
04-21-2004, 12:59 | #14 (permalink) |
Member: 17193 Status: Offline Thanks Meter: 16 | Do that. It solved my 'Disconnect IrDA' problem, believe me. About that other v200 problem, it could easy be flat cable failure... Check the flat cable connector, maybe it has some corrosion on it, or on the display part. |
2600c camera problem need help | ..::M-GSM::.. | Nokia Hardware & Hardware Repair | 20 | 11-15-2010 15:58 |
N5300 strange camera problem,need help !!! | andest | Nokia Base Band 5 ( BB-5 ) | 2 | 11-01-2008 15:03 |
W810 camera problem need help | skd_123 | Sony Ericsson Media, RingTones, Games | 0 | 09-01-2008 09:34 |
K750 Camera Problem Need Help | MRALI_BHAI | Sony Ericsson Hardware Repair | 2 | 08-28-2008 23:40 |
V200 Flashing Problem-need help urgent. | dominik | Trident/AGERE Platform | 2 | 07-19-2003 18:13 |
