Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900. |
07-10-2004, 12:04 | #1 (permalink) |
Insane Poster Join Date: Oct 2003 Location: moroco Age: 54
Member: 41880 Status: Offline Thanks Meter: 5 | i need a methode clear for flashing samsung s300 |
07-12-2004, 07:06 | #4 (permalink) |
Insane Poster Join Date: Jan 2004 Age: 53
Member: 50821 Status: Offline Thanks Meter: 0 | HOW TO FLASH/BACKUP Firmware With: OPTIFLASH Quick Tutorial A. Switch the cable to DATA B. Remove the cable from your phone C. Remove your battery D. Put your battery back after 5secs E. Put the cable in the phone [ Now your screen is white ] F. Select the firmware and push the flash button PS: Make a BACKUP FIRST G. When Optiflash says 'Hit On/Off Button' Push the on/off button 1 second and the screen should go black leave the phone connected to your cable. Expanded Tutorial 2. YOUR FIRMWARE (Prior to doing all these steps, take out your SIM card and make sure your phone is off). A. Unzipped these files to a folder. Open the Optiflash.exe file and go to Options=>Settings=>Backup. Clear all the information from the Backup Range field and add the following: 0x00000000 - 0x00001fff 0x00004000 - 0x00ffffff Also add the following range if your phone has 2 chips: 0x01000000 - 0x01ffffff B. You can save the file to whatever name you want in the Save File field. The default name is Save.sre. Click OK C. Go the Com Port tab and for the first Comp Port select the correct port that your data-cable is connected to. For the second COM Port select none. D: Go to the General tab and select Your Phone Model in the Select your Phone Model field and press OK and it should bring you back to the Optiflash - [Samsung] box. E: Connect your phone to the data-cable and click on the Backup button. Then press the power button on your phone. *Note that your phone will not be on but the program should start backing up your rom. F. After this is done you should get a message that says "Remove Cable" in the log. G. Detach your phone from the data-cable and take out the battery for about ten seconds and put the battery on after that. Now you are ready to flash your firmware. 3. (Firmware upgrade) A. Go back to the Optiflash main window. B. Than click on Browse... and select the .s3 or .sre ROM it should be in the folder where you extracted the files. C. Make sure everything there is blank In the Reserve Memory regions. At Options=>Settings=>Flash & Verify and Click OK. D. Attach your phone again to the data-cable and press the Flash button. Then press the power button on your phone. (Note that your phone will not power on but the program should start running). This process took about 15-30 minutes on my phone. When it is done it should say "Remove Cable" in the log. E. Detach your phone from the data-cable and take out the battery for about four seconds. Then put the battery back on and power up your phone. You are done flashing your ROM If you get stuck, tell me where and I will try to help. |
I need a unlock code for a samsung sgh-x450 | luismacpestana | Phone Unlocking Codes & Maps | 5 | 07-29-2013 23:23 |
For you which is the best solution for flash samsung phone ? | gsmnice | Samsung Flashers, Software, Firmware. | 1 | 02-26-2006 20:41 |
help for flash samsung D500 | ParsX | UFS2 + UFS3-Tornadoflasher | 1 | 11-15-2005 20:27 |
I need the unlock codes for a Samsung E 105 | Mavsale | Phone Unlocking Codes & Maps | 1 | 07-17-2004 09:29 |
