Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900. |
![]() | #46 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2003 Location: Twin Towers Age: 31
Member: 30582 Status: Offline Thanks Meter: 1 | Quote:
Only when u select wrong loader or wrong setting then give error messages,better post screenshot or more infos,then others can help u. best regards | |
![]() | #51 (permalink) |
Junior Member Join Date: Jul 2004 Age: 52
Member: 72250 Status: Offline Thanks Meter: 0 | Elco - you are a Samsung ***. Perhaps YOU might actually be able to answer this one question no one else seems able to answer: I now have an E105 - my friend tried to unlock it and now it says "Phone locked. Return for servicing" so she dumped it on me. Will flashing this phone with E105Full_uvwl2_English firmware using Optiflash 3.6 fix this error? (related - will I have to reset the IMEI number after flashing it with this firmware? Or any other special instructions?) Thank you again - you are an Ace. I've been struggling with this for weeks... |
![]() | #52 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Jan 2004 Age: 49
Member: 50821 Status: Offline Thanks Meter: 0 | Wopanese wrote: Perhaps YOU might actually be able to answer this one question no one else seems able to answer: I now have an E105 - my friend tried to unlock it and now it says "Phone locked. Return for servicing" so she dumped it on me. Will flashing this phone with E105Full_uvwl2_English firmware using Optiflash 3.6 fix this error? (related - will I have to reset the IMEI number after flashing it with this firmware? Or any other special instructions?) I have been seeing in other Forums that this is a common problem with the 105/715 and 710 models. Normally caused by inputting the OLD unlock codes in more than 4 times. What I can gather is: This fault will NOT be rectified with flashing(At least it does not work with 71* series) Somehow the fault is not FW embedded it seems it affects eprom. Normally after a flash you do not need to change IMEI no. But if you Modify the FW with Janukas Firmware browser then flash it, this tends to alter your IMEI no.s Now Elco. Thanks Bud for the regular Opti-Updates you're a star. Any chance of an E800 compatible version in the near future? |
![]() | #53 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,393 | Yes.U can repait that phone by flashing with optiflash(full flash-50Mb) Imei will be changed after flash.U can change back imei with winimei for E105. FOR E105 PHONE USE ONLY WINIMEI FOR UNLOCK.UST DESTROY THAT PHONE |
![]() | #54 (permalink) | |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,393 | Quote:
first:If u write full flash(50Mb) on E105 imei will be changed.(on E71x will not be changed) Yes.Soon E800,E810 will be added to optiflash | |
![]() | #59 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2003 Location: Boston
Member: 21920 Status: Offline Thanks Meter: 10 | Quote:
![]() | #60 (permalink) |
Member: 72250 Status: Offline Thanks Meter: 0 | Thanks very much for all the help. I guess the question now is how to get winImei. I have a version but it does not let me enter the full IMEI number - it's 1 digit too short. Maybe I need a newer version of winImei? Or do I need to leave off one of the digits when I enter the numbers? I'm reading the IMEI off the original box barcode and it is the same inside the phone, except the number on the phone itself has some dashes and slashes in it... Thanks very much again to everyone for the help so far - I think I am finally on the home stretch with this problem!! ![]() |
Here E710 & E710 Flash Files + OptiFlash... | vanitas69 | Trident/AGERE Platform | 36 | 07-14-2005 00:37 |
I need D410 E600 X430 X450 turkish and russian flash files | bigstarfirst | SYSOL Platform | 10 | 05-11-2005 15:28 |
D410 X450 X430 E600 | bigstarfirst | UST Pro II | 2 | 08-27-2004 17:04 |
Arabic X430 - X450 - D410 | ARC | Trident/AGERE Platform | 0 | 07-09-2004 12:19 |
