Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900. |
05-04-2004, 22:55 | #1 (permalink) |
Insane Poster Join Date: Dec 2003 Location: Algeria Age: 44
Member: 47325 Status: Offline Thanks Meter: 0 | Pls wich Cable for Flash S300 i tried with Much Cable and Optiflash under XP , but now succes , pls anyone tell me what Cable tested and worked ?. the phone was damaged by me .. best regard |
05-05-2004, 21:02 | #2 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Use Windows XP Goto TAB Flash & Verify & remove all the addresses from there there must no addresses in Flash & verify Page OK & Use T100 Original Cable for this Process TESTED by me 100% & also use COm 1 & 115200 baud rate speed !!! Best of Luck !!! Regards Aamir Zia |
05-05-2004, 22:56 | #3 (permalink) |
Member: 47325 Status: Offline Thanks Meter: 0 | Thanks AmirZ , i will do it with T100 original , but i want to tell you that i am working to make the new PackLanguage for Samsung New Sets for Free , then if you have some pack Languege pls send it to me , i am almost done 50 % of the prog thanks in advance Badrou |
05-06-2004, 04:08 | #4 (permalink) | |
No Life Poster Join Date: Nov 2003 Age: 46
Member: 43076 Status: Offline Thanks Meter: 10 | Quote:
6020 ufs3 wich cable for flashing | latemer | Nokia Hardware & Hardware Repair | 3 | 07-20-2006 16:32 |
..::Software::.. Wich cable for Wich Samsung | GsmTower | Samsung Flashers, Software, Firmware. | 30 | 07-13-2006 15:19 |
cable for flashing S300 pin out | flechazo | Trident/AGERE Platform | 0 | 09-28-2003 16:50 |
