Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Trident/AGERE Platform
Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900.
Old 05-28-2011, 16:48   #1 (permalink)
Member: 1404245
Thanks Meter: 73
Samsung B3210 amazing problem ........
Hi
I found today my samsung b3210 amazing problem: -
1. when receiving or making any calls , there is no sound in ear-peace, mic & ringer.
but if I go into loudspeaker mode, all three (ear-piece , mic & ringer working perfectly.
What i have tried till now :
1. full flash using ufs & z3x
2. Full flash with original flasher.
3. Full erase & again full flash.
but no solution.
if it is hardware problem , plz help me to find out that.
I need only tested solution.
Thanks
The Following User Says Thank You to satrughna For This Useful Post:
Old 06-22-2011, 17:04   #2 (permalink)
Member: 104604
Thanks Meter: 24
I have the same problem any solution for that problem ?
Old 06-22-2011, 17:37   #3 (permalink)
Member: 104604
Thanks Meter: 24
Problem solved.
Dissasembling the phone ,clean mainboard with toothbrush and the end rehot place where wire touch main borad for earspeak and then assembling the phone and all working perfect.
Old 07-02-2011, 16:49   #4 (permalink)
GORAN_CRO's Avatar
Member: 58120
Thanks Meter: 4
*2767*3855# -> phone work normal
Problem solved.
Old 07-04-2011, 10:42   #5 (permalink)
Member: 1102270
Thanks Meter: 5
segments 9
segment 1 20300000 37196200 byte
segment 2 2001E000 180 byte
segment 3 20016000 26012 byte
segment 4 20000000 100 byte
segment 5 200A0000 1136340 byte
segment 6 2000C000 21592 byte
segment 7 20080000 56 byte
segment 8 20080138 20282 byte
segment 9 2003803C 125512 byte
Phone must be OFF with battery
Please, connect phone and press shortly power button
Syncing phone... OK
Sending loader 1... OK
Syncing phone... OK
Sending loader 2... OK
Syncing phone... OK
Syncing phone... OK
Flash ID: 89000000B088
Syncing phone... OK
Sending *.s3 file...
bad ask - +ok!
Send s3 - fail
Elapsed time: 746 second, sw ver: 3.5.0008
samsung b3210 menu miss mach help me
Old 07-04-2011, 11:02   #6 (permalink)
ridowan's Avatar
Member: 473043
Thanks Meter: 30
I have same problem.anybody have test solution?
Old 06-07-2012, 08:02   #7 (permalink)
Crazy Poster
Member: 1075004
Thanks Meter: 13
B3210 speaker and mic not working
try this bro. i hope ur mobile will be normal
The Following User Says Thank You to shukla nikunj For This Useful Post:
Old 07-07-2012, 18:04   #8 (permalink)
Member: 1002906
Thanks for the solution. Ear piece 100% working
The Following User Says Thank You to kwakuowusu For This Useful Post:
Old 02-05-2013, 11:37   #9 (permalink)
Member: 1762926
Sonork: 1619564
Thanks Meter: 83
http://i47.tinypic.com/suypnq.jpg
100% tested b3210 ringer solution
The Following User Says Thank You to active_care For This Useful Post:
Old 02-05-2013, 11:38   #10 (permalink)
Member: 1762926
Sonork: 1619564
Thanks Meter: 83
Old 10-15-2014, 05:59   #11 (permalink)
Member: 1534437
Sonork: faza
thank you for all the kindness
Old 05-08-2015, 09:37   #12 (permalink)
ibhandari's Avatar
Member: 1621490
Thanks Meter: 154
Originally Posted by pradeep varma View Post
segments 9
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
bad ask - +ok!
Send s3 - fail
same prob help me anybody..
[IMG] code is Off
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 19:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.23939 seconds with 10 queries
