Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900. |
11-26-2012, 17:00 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Samsung M2513 please wait tested solution phone: sam M2513 problem: auto off after power on and show please wait device: ufs3(hwk) need more: usb cable c1-01 action taken: *First flash phone with Hwk but not solve *then download this down loader M2510_B3310_OptiFlash *action process ............................ Firmware Update Steps: 1. Run Samsung M2510 Downloader.http://hotfile.com/dl/61569596/103a6...Flash.rar.html 2. Select Customer T: Disco (Intel Sibley 512/256, USB). 3. In Flash Option section check: Code Binary and CSC Binary(Default). 4. Also check this Option: Erase all Unused Regions. 5. Connect the phone in Download mode: (Press volume - and press 9 at a time for a while then release both key) then connect USB cable to phone. 6. Now select the Com Port that the phone takes. 7. Select the S3 Flash file and CSC file too, each in his field. 8. Click on Flash button and type YES in the message box then click OK to Start the process. 9. Do not touch or remove the cable till the Program tell you: All is Well. 10. Turn On the phone and do full reset by the code: *2767*3855#. *download this flash file from hwk server M2513DXIL1_OLAII1 here the flash log http://img853.imageshack.us/img853/8315/flashlogh.jpg full working log http://img850.imageshack.us/img850/3...1211262128.jpg after this work now phone alive but it ask for phone lock code then make info and get the code by hwk log here Software: M2513DXIL1 Regions : Indonesia,Java,Malaysia,Singapore,Thailand,Vietnam Language: en,id,jv,ms,th,vi,zh(ta) Release : 2009 December Rev: 1 CSC Vers: M2513OLAIF1 Regions : LA Release : 2009 June Rev: 1 Hardware: MP 0.800 IMEI: 355799-03-014804-1 BT Address: 00265f-929301 User Lock : 25801 Lock Level: 00 [Not Locked] MSL : Active S/N : RQES806407 To Make MSL Bypass in USB Mode, Use [Repair MSL] at first ! (not need to Write E2P or MCU ) Locks: Error that means after now everyone can solve this problem with this tutorial. to know more about this problem just ask here.i will try to give you reply some failed and same history like this thread added here http://forum.gsmhosting.com/vbb/f200...lasher-993710/ samsung m2513 flash problem sam gt-m2513 phone lock code How to flash m2513 please wait problem |
The Following 3 Users Say Thank You to ..::Gsmideazone::.. For This Useful Post: |
11-27-2012, 05:50 | #2 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Thanks My Friend For A To Z Solution Hello Every One Hit Thanks Like Me If This Thread Help You Br, ..::azimbahar::.. |
The Following User Says Thank You to aZimBahar For This Useful Post: |
