Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900. |
09-02-2008, 22:14 | #18 (permalink) |
Junior Member Join Date: Jul 2008
Member: 824064 Status: Offline Thanks Meter: 1 | Code: 5- now type : *7465685*638*00000000*00000000# your UNLOCK CODE is 00000000 now , hh Enjoy :D |
The Following User Says Thank You to ragsger For This Useful Post: |
09-05-2008, 19:05 | #23 (permalink) |
Junior Member Join Date: Sep 2008
Member: 854600 Status: Offline Thanks Meter: 0 | [QUOTE=crack3war;3277841]This method is maybe known for some of you , i test it for some models (like E250 ,J700 ..) and i think , it can work for all other models .. It's easy ,no risk at all , no cable , no drivers , but need to be handled well Today i test it on J700 , as we know ,many of us have a bad result after using box to unlock that fone ,, (bad Imei ,bad BT adress ... ) but with this method ,, EVERYTHING is FiNe 1- Power on fone ,, type : *#7465625# you will identify wich code is active , wich is inactive 2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on fone ,, you must see " insert sim" not "invalid sim.." 3- type : *2767*3855# your fone should restart after 1 min ,, now ,, and before it restart , push your sim card ,,without removing battery 4- your fone should work and accept the sim card ,, but if you chek locks you will find that your fone is still Loked 5- now type : *7465685*638*00000000*00000000# your UNLOCK CODE is 00000000 now , hh Enjoy 6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,here details : * Disables CP lock : #7465625*27*00000000# * Disables Network lock : #7465625*638*00000000# * Disables SIM lock : #7465625*746*00000000# * Disables SP lock : #7465625*77*00000000# * Disables Subset lock : #7465625*782*00000000# I wish It help , Regards[/Brilliant. It works!!! So happy QUOTE] |
09-06-2008, 08:39 | #24 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Erirea
Member: 825233 Status: Offline Thanks Meter: 10 | my phone says phone freezes!!! thax for your great work .but i tried this method 10 times and i couldnot pass the second step during reboot i inserted but i couldn't get to the phone only it says enter pasword please help me |
10-03-2008, 12:57 | #25 (permalink) |
Junior Member Join Date: Oct 2008
Member: 875796 Status: Offline Thanks Meter: 1 | Thanks crack3war... just purchased a J700, and had the network lock. Followed your instructions 1 to 4 absolutely fine, but when it came to no. 5 '5- now type : *7465685*638*00000000*00000000# your UNLOCK CODE is 00000000 now' When I press send, I get 'please wait network action' this is quickly followed by 'Not Allowed' This means in my case that the Network Lock and the SP Lock are still in place. Can anyone please help??? |
10-26-2008, 21:25 | #26 (permalink) | |
Junior Member Join Date: Jun 2008
Member: 796873 Status: Offline Thanks Meter: 0 | do some thing for SP lock brother its nice post but it would be highly appreciated if u fix the SP lock solution. please do some thing for SP lock. Quote:
10-27-2008, 08:19 | #27 (permalink) | |
No Life Poster Join Date: Aug 2008 Location: pakistan
Member: 828294 Status: Offline Sonork: 100.1615866 Thanks Meter: 124 | Quote:
The Following User Says Thank You to zeeshan tayyab For This Useful Post: |
10-29-2008, 13:36 | #28 (permalink) |
No Life Poster Join Date: Feb 2003 Location: EAST AFRICA! TANZANIA
Member: 22893 Status: Offline Sonork: 100.1607086 Thanks Meter: 131 | J700 free unlock USE #*7337# unlock samsung e250,j700 and finally *7773# Tested two pieces 100% |
The Following 3 Users Say Thank You to mkwatis For This Useful Post: |
10-30-2008, 08:45 | #29 (permalink) |
Member: 828294 Status: Offline Sonork: 100.1615866 Thanks Meter: 124 | bro,its effective no doudt but the option is to disable the network code does not work,i try it on j700 it accept the sim but cant disable the code,,,,,,,,,,,try to work it and post. |
11-01-2008, 12:48 | #30 (permalink) |
Member: 22893 Status: Offline Sonork: 100.1607086 Thanks Meter: 131 | @zeeshan tayyab This method is maybe known for some of you , i test it for some models (like E250 ,J700 ..) and i think , it can work for all other models .. It's easy ,no risk at all , no cable , no drivers , but need to be handled well Today i test it on J700 , as we know ,many of us have a bad result after using box to unlock that fone ,, (bad Imei ,bad BT adress ... ) but with this method ,, EVERYTHING is FiNe 1- Power on fone ,, type : *#7465625# you will identify wich code is active , wich is inactive 2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on fone ,, you must see " insert sim" not "invalid sim.." 3- type : *2767*3855# your fone should restart after 1 min ,, now ,, and before it restart , push your sim card ,,without removing battery 4- your fone should work and accept the sim card ,, but if you chek locks you will find that your fone is still Loked 5- now type : *7465685*638*00000000*00000000# your UNLOCK CODE is 00000000 now , hh Enjoy 6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,here details : * Disables CP lock : #7465625*27*00000000# * Disables Network lock : #7465625*638*00000000# * Disables SIM lock : #7465625*746*00000000# * Disables SP lock : #7465625*77*00000000# * Disables Subset lock : #7465625*782*00000000# full procedure can disable |
NEW Samsung's j700 & j600 unlocking for FREE | Jazzy_j_2000_uk | SWIFT Platform | 4 | 01-06-2019 16:42 |
--= PROMOTION - C O N T I N U E S !!! : All A1/A2/S1 unlocks FOR FREE till Apr 12 =-- | Mizar | Cruiser Suite | 387 | 04-30-2010 16:25 |
All A1/A2/S1 unlocks FOR FREE no need ACTIVATION | nanoy | Cruiser Suite | 14 | 04-03-2010 14:31 |
Samsung's unlocking for FREE M310 M620 L320 B520 | hassan riach | Trident/AGERE Platform | 5 | 03-10-2010 20:08 |
NEW Samsung's j700 & j600 unlocking for FREE | Jazzy_j_2000_uk | Trident/AGERE Platform | 3 | 08-05-2009 13:39 |
