Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Trident/AGERE Platform
Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900.
Old 08-19-2003, 09:06   #1 (permalink)
Member: 7444
Sonork: 100.99999
Cool Solution for repair V200 "Remove IRDA or Data Cable" HERE!!!!!!!!!!!!
Look here : http://www.vsh-gsm.com/forum/viewtopic.php?p=342#342
WBR
Vahid Shahabi
Old 08-19-2003, 09:19   #2 (permalink)
Moderator
Syed's Avatar
Member: 19979
sounds good!!!!!
lets check it out :-)
WBR
Syed
Old 08-29-2003, 00:39   #3 (permalink)
Member: 32369
But you need to register..............?? can you post on here instead
Old 08-29-2003, 08:26   #4 (permalink)
vz
Member: 4372
Dear Vahid Shahabi!!!
Why registration procedure is so paranoid? Why don't you make it easier?
Old 08-29-2003, 12:55   #5 (permalink)
Burnt Cobba's Avatar
Member: 11325
thanks for the solution Vahid but the problem remains that the epoxy glue must be removed if there is presence and also no idea fro mwhere to get that blessed Trident IC.
al
Old 08-31-2003, 11:25   #6 (permalink)
alfamobilTEAM's Avatar
Member: 22553
can repair this via flash? i have V200 i flashing this phone (i put arabic lang)and now "remove IRA or cable..bla bla". is possibile repair this via flash?
Old 09-02-2003, 12:08   #7 (permalink)
Member: 17711
There is no way to repair it by flashing.
Old 09-02-2003, 16:31   #8 (permalink)
Moderator
Syed's Avatar
Member: 19979
i also had this problem when i tried to upgrade my V205 to V200 but i flashed the phone with backup and had my camera working again....
WBR
Syed
Old 09-04-2003, 08:56   #9 (permalink)
Member: 11325
@syed
mate did u meet the problem of V200 that when camera is switched on the screen goes black?
thanks
al
Old 09-04-2003, 10:21   #10 (permalink)
Moderator
Syed's Avatar
Member: 19979
@Burnt Cobba
i had this problem once in my 7250 which i fixed by flashing but never in V200 why not try to flash it....but remember to make back up first.....
WBR
Syed
Old 09-04-2003, 18:45   #11 (permalink)
Sun
Sun's Avatar
Member: 17084
No need change IC, only flash with firmware V25UVVL2. I'm repair 5 phone work fine
Old 09-04-2003, 19:14   #12 (permalink)
Member: 7444
Sonork: 100.99999
Yes, SW case can be solved by flashing with V205 flash.
But HW case, ONLY CHANGE FLASH IC!
Old 09-05-2003, 02:25   #13 (permalink)
Member: 6881
Hi Sun
Where can I get this FW?
Old 09-05-2003, 05:56   #14 (permalink)
Sun
Sun's Avatar
Member: 17084
Originally posted by say2k
Hi Sun
Sorry i fogot it's i'm loaded in 1 month ago
Pls find in some site
[IMG] code is Off
V200 remove IRDA or cable solutionnnnnnnnnnnnnnnnn edy2002gha Samsung Hardware Repair Area 34 03-17-2010 10:46
Need solution for D410 "REMOVE IRDA or CABLE" haider Samsung Hardware Repair Area 6 02-17-2006 21:20
V200 remove irda or data cable .:Kuku:. Trident/AGERE Platform 9 07-03-2005 22:35
any solution for D410 "REMOVE IRDA or CABLE"??? ghosthacker Samsung Hardware Repair Area 2 06-11-2005 09:53
V200 remove irda or data cable .:Kuku:. Trident/AGERE Platform 0 05-24-2005 14:49
Page generated in 0.38154 seconds with 11 queries
