Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Trident/AGERE Platform
Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900.
Old 11-30-2007, 14:55   #1 (permalink)
Member: 254709
successfuly unloked samsung M600
with ns pro e210 cable and jaf port emulator i started lucifer vers. 1.03 then stack reset and cust reset.... unlock done
can anyone tell me how to convert nspro cable to ust pro?
thanx in advance
The Following User Says Thank You to ashrak For This Useful Post:
Old 12-23-2007, 09:18   #2 (permalink)
Member: 124854
thanks your solution work perfect
Old 12-23-2007, 10:54   #3 (permalink)
simba1805's Avatar
Member: 92500
for the pinout just look for pinouts for both boxes then make modification
Old 12-23-2007, 14:32   #4 (permalink)
Member: 656764
some one please tell me what to do with samsung sgh u700v its un lock and freeze its network lock please let me how to make it work thanks
Old 12-23-2007, 14:40   #5 (permalink)
Member: 656764
help please i have samsung sgh-u700v but its network lock and phoon freeze also any one help me please
Old 01-07-2008, 13:37   #6 (permalink)
GSM MIND's Avatar
Member: 20645
Sonork: 100.1579175
ALWAYS POST ONCE AND WAIT FOR REPLY IF ANY BODY KNOWS ABOUT IT SHOULD POST HERE
REGARDS
GSM MIND
Old 01-07-2008, 19:20   #7 (permalink)
Member: 673890
Hi everybody, Does someone know how i can unlock a samgung-a737?
Thanks!
Old 01-12-2008, 03:16   #8 (permalink)
Member: 74814
hi,
i have tried but cannot seem to detect phone, please post some details
tia,
Old 04-09-2008, 07:27   #9 (permalink)
Member: 7586
which cable did u used ?
usb or com for unlock ?
Same as for g800 l760 e210 ?
b.r.
pali
Old 05-26-2008, 14:21   #10 (permalink)
HAMMZA_MOBILES's Avatar
Member: 718939
M600 successfuly unlocked with USTPRO2.
use E210 cable
set power on
select m600 model
and direct unlock
thanks ust team
The Following User Says Thank You to HAMMZA_MOBILES For This Useful Post:
Old 09-22-2008, 13:34   #11 (permalink)
Member: 23786
with HWK,
use cable E210, tick model C200 and direct UNLOCK and all is OK
The Following User Says Thank You to vmobil For This Useful Post:
[IMG] code is Off
samsung m600 imei 00000000000 repair Uno_x HWK 21 09-23-2011 14:09
SUCCESSFULY unlocked Samsung J400 with Rocker..see inside chatfan Rocker Dongle (By Legija) 0 07-13-2009 21:19
samsung m600 pinout cable WANTED VasiliuS Trident/AGERE Platform 11 07-08-2008 20:42
Samsung M600 Charging Problem rkinfo_imran Samsung Hardware Repair Area 0 04-07-2008 21:10
....need pin out samsung M600 xxtcdthuanxx Samsung Flashers, Software, Firmware. 1 10-16-2007 13:14
Page generated in 0.39598 seconds with 11 queries
