Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900. |
07-25-2006, 21:41 | #5 (permalink) |
Freak Poster Join Date: Oct 2003
Member: 41523 Status: Offline Thanks Meter: 8 | unlock hi connect powered down phone to comp with original usb press *+pwr 3 sec (windows will ask for drivers,install from orig cd) go to device manager,see the number of com port connected put this number in sus (or any other e900 prog) flash and unlock p.s. flashing with sus will 000000.... your imei flash phone with opti if anyone has imei prog for e900 please post it tnx |
09-04-2006, 15:16 | #6 (permalink) |
Freak Poster Join Date: Jun 2005 Location: london
Member: 153584 Status: Offline Thanks Meter: 4 | Is the d820 cable also used to repair imei on the e900, could someone please confirm this and does anyone know of a cheap solution to doing this as i only want to repair 1 phone |
09-17-2006, 22:20 | #7 (permalink) |
Freak Poster Join Date: Aug 2006 Location: egypt
Member: 332555 Status: Offline Sonork: 100.114258 Thanks Meter: 30 | i tried to flash e900 with d800 cable but nothing at all happen i also modified the d 800 cable still the same what a mess can ust pro team tells us what kind of cable used with e 900 thankxxxxxxxxxxxxxxxxxxxxxxxx |
UstPro2 Cables | baljitsb | UST Pro II | 2 | 03-30-2010 13:35 |
NEC n930 usb cable and charger needed | przemekj | NEC | 0 | 03-29-2010 15:21 |
Pinout E900 cable? | Angello | Ultimate-Sam | 2 | 01-24-2009 20:21 |
e900 cable | TALLSAJ2 | UST Pro II | 2 | 07-15-2006 00:05 |
