Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > SYSOL Platform
SYSOL Platform S500, S508, D488, E100, E330, E335, E338, E630, E635, E638, E700, E708, E800, E808, E820, P300, X100, X108, X460, X468, X490, X495, X600, X608, X620, X628, X640.
Old 11-17-2013, 09:31   #31 (permalink)
Registered User
Member: 2056634
Sonork: www.sonork.com
Thanks Meter: 3
i need g93 rda 8851a gd25q32 flash file thanks in advance
Old 11-22-2013, 10:20   #32 (permalink)
Member: 1581426
Sonork: 100.876544
flash process done, but blinking problem not solve.
Old 11-23-2013, 14:20   #33 (permalink)
Member: 2069706
after flash just started and then off with in two 2sec
Old 01-31-2014, 08:31   #34 (permalink)
sunil_plan2000's Avatar
Member: 1563653
Sonork: 100.1640878
Thanks Meter: 15
all tick then flash trick works but imei damage
Old 02-04-2014, 10:30   #35 (permalink)
uniontelecom's Avatar
Member: 1538904
Sonork: 100.1603095
Thanks Meter: 198
For Imei Repair Use Ufs\Z3x\Octopus Or Spt That s All.
Old 03-01-2014, 14:51   #36 (permalink)
ashish800's Avatar
Member: 1889562
Thanks Meter: 617
e2252 blink solution........
(1) write og flasher.
(2) chek battry conecter sens supply ,with multimeter reading show.
(3)chek orignal full charge battry
(4) tick all csc file page then flash it
The Following User Says Thank You to ashish800 For This Useful Post:
Old 03-14-2014, 07:27   #37 (permalink)
Member: 1944659
help me
hello for which cable i use for flashing bro.........
Old 03-20-2014, 17:39   #38 (permalink)
Momin_Telecom's Avatar
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,806
Originally Posted by uniontelecom View Post
Samsung E2252 Blinking Solution
Here Is File And Flash In
E2252_New tested
E2252_New tested.rar
Thanks & Regards
Vicky
yes this working for me tested file follow instruction ,ll be done
The Following User Says Thank You to Momin_Telecom For This Useful Post:
Old 04-05-2014, 06:19   #39 (permalink)
Member: 2137196
how repair dead problem in samsung E2252 ?
Old 04-05-2014, 07:35   #40 (permalink)
doriwala1's Avatar
Member: 2056905
Sonork: 100.1654355
Thanks Meter: 170
Flash Via
Flash Loader 7.5.4
Best Regards
Nikku Dori
Old 04-12-2014, 18:10   #41 (permalink)
Member: 1178113
Thanks Meter: 44
yes 100% working see you tube link below
SAMSUNG E2252 WRITE FLASH - YouTube
Old 05-06-2014, 14:44   #42 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,110
Samsung E2252 One More Done :) ;)
http://s17.postimg.org/bji6ybvov/e2252.png
Bro:- Palash Ahammad
Old 05-13-2014, 15:06   #43 (permalink)
Member: 1727949
Sonork: durgeshmodi
Not solving problem only one way change BT 1000 mah
Old 06-08-2014, 08:46   #44 (permalink)
Member: 1172662
Sonork: 100.1625907
Thanks Meter: 9
Question
E2252_New tested
Thanks & Regards
Vicky
hello have you the solution for this kinds of problem e2252 set blinkig with white display i did as flash with deferent versson like xxma,ddie with deferent box like z3x ufs hwk flash loader 7.5.4 and also write eep from hwk support but still same problem blinking white display any new idea
Old 09-03-2014, 23:41   #45 (permalink)
Member: 1487405
Sonork: NO
Thanks Meter: 43
txs for solution but blinking .sorry for my English
to fix problem blinking you need to custume repaire imei with z3x and .txs ..
[IMG] code is Off
Page generated in 0.18707 seconds with 8 queries
