Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| SYSOL Platform S500, S508, D488, E100, E330, E335, E338, E630, E635, E638, E700, E708, E800, E808, E820, P300, X100, X108, X460, X468, X490, X495, X600, X608, X620, X628, X640. |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2000 Location: next to you ; )
Member: 1133 Status: Online Thanks: 58
| Samsung E800 Set hang Hi all. Does anyone have any solution where when the phone powers up, it shows the "Samsung" logo and then the screen turns black?? The phone is still in a wake-up mode even though the display is all black. Seems like a software problem but there simply isn't enough tools around to muck around with this model yet. Your suggestions much appreciated Best Regards to all |
| | #2 (permalink) |
| Registered User ![]() ![]() ![]() ![]() ![]() Join Date: May 2004 Location: south africa Age: 30
Member: 66075 Status: Offline Thanks: 0
| seems like nand flash ic might might be freezing did u try and replace nand flash ic or before you try that try to flow the board |
| | #4 (permalink) | |
| Both pieces have the same and they are brand new. I suppose it is like the first batch of E700 that froze after startup which requires you to write a full flash to repair this problem. Does anyone have any other suggestions? Thanks ! Quote:
| | #5 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2003 Location: UK MANCHESTER Age: 38
Member: 28588 Status: Offline Thanks: 8
| Hi guys i have a problem with my E800, when power on only white screen any ideas the sound is still there, was working fine till other day, no contact with water or droped, best regards Lee5k |
| | #6 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2004 Location: Athens - Greece Age: 45
Member: 59935 Status: Offline Thanks: 25
| Quote:
I have the same problem. White screen. Phone make and receive calls. When you put a charger (not ever) phone beep and the display show "charging" as normal ... then i power it on and phone works fine ... After power off and on agan ..... the same ...WHITE SCREEN...I flash it with UFS ... problem exist ... E2P reset ... unlock ... the same... Any solution ????? | |
| | #7 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2003 Location: DUBAI
Member: 26500 Status: Offline Sonork: 100.101633 Thanks: 178
| Hi Mr Baboom change the LCD flex cable if phone is working. Mr Phantom- Pls try to formatt nand and then flash the phone bin+tfs file. |
| | #8 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2003 Location: Australia
Member: 44593 Status: Offline Thanks: 5
| e800 Quote:
my e800 no sound . i dont think there is a problem with speaker and buzzer.. please help thanxxxxxxxx | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 1209 1 minute set ok next set hang | yakkathali | Nokia Hardware & Hardware-Repair Area | 4 | 01-03-2010 14:11 |
| nokia 6630 stie photo is set ok make movie set hang and restert | ..::ohm::.. | Nokia Hardware & Hardware-Repair Area | 1 | 01-14-2008 07:23 |
| Samsung E800 | .:GSM International:. | SYSOL Platform | 25 | 07-23-2005 05:21 |
| @ Elco- E800 set hang, Please help. | Phantom | SYSOL Platform | 2 | 10-10-2004 15:35 |
| Samsung E800 English Firmware Flash | trixnr1 | SYSOL Platform | 1 | 07-22-2004 19:30 |
