Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
03-16-2014, 08:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: india Age: 36
Member: 690456 Status: Offline Sonork: 1587650 Thanks Meter: 117 | after update wifi not work i have one s4 i9505 that one before lock i do just update that one after wifi not work how can fixx it plz help me any body |
03-17-2014, 02:00 | #4 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Your wifi Mac address may be null. U should download Wi-Fi fix and copy this file to ur system. |
The Following User Says Thank You to chandanps18 For This Useful Post: |
03-18-2014, 07:59 | #8 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Heaven Age: 35
Member: 2141811 Status: Offline Thanks Meter: 38 | If you have a WiFi permanently disabled or very weak, try to do it: Open the file /system/etc/firmware/wlan/prima/WCNSS_qcom_cfg.ini in text editor. Change the line gEnableBmps = 1 to gEnableBmps = 0 Save and reboot This increases the stability of the WiFi and fixes WiFi from regular stops. |
03-21-2014, 10:24 | #13 (permalink) |
Member: 2141811 Status: Offline Thanks Meter: 38 | [Tuts] How To Root Samsung Galaxy S4 GT-I9505 On The Latest OS Tutorial Step 1: Download both CF-Auto-Root Android 4.4.2 Package and ODIN3, and extract the files to the computer. Step 2: Power off the handset and put it in Download mode by pressing and holding down the Volume Down, Home and Power buttons together. After a warning screen appears, press the Volume Up button to enter Download mode. Step 3: Run Odin3 v3.09.exe as an Administrator while the phone is Download mode, and connect the Galaxy S4 to the PC via USB cable. If connected successfully, a message showing “Added!!” will appear in Odin’s message box. Step 4: Now, click on the AP button, and select the CF-Auto-Root file that was extracted in Step 1. Step 5: In Odin, check the “Auto Reboot” and “F. Reset Time” options. Step 6: Click on the Start button in Odin to begin the flashing process. Step 7: Once the process is complete, the Galaxy S4 will restart and a PASS message with green background will appear in the left-most box at the top of Odin. You can now unplug the USB cable to disconnect the handset from the PC. If This helps u just press Thanks Button |
The Following User Says Thank You to bishnuprasad884 For This Useful Post: |
