Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 03-29-2010, 12:09   #1 (permalink)
Member: 762436
Sonork: cs/09401
All codes for samsung mobiles.......[check this out...]
*#06# -> Show IMEI
*#9999# -> Show Software Version
*#0837# -> Show Software Version (instructions)
*#0001# -> Show Serial Parameters
*#9125# -> Activates the smiley when charging.
*#9998*228# -> Battery status (capacity, voltage, temperature)
*#9998*246# -> Program status
*#9998*289# -> Change Alarm Buzzer Frequency
*#9998*324# -> Debug screens
*#9998*364# -> Watchdog
*#9998*377# -> EEPROM Error Stack - Use side keys to select values. Cancel and ok.
*#9998*427# -> Trace Watchdog
*#9998*523# -> Change LCD contrast - Only with version G60RL01W
*#9998*544# -> Jig detect
*#9998*636# -> Memory status
*#9998*746# -> SIM File Size
*#9998*778# -> SIM Service Table
*#9998*785# -> RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*786# -> Run, Last UP, Last DOWN
*#9998*837# -> Software Version
*#9998*842# -> Test Vibrator - Flash the screenligth during 10 seconds and vibration activated.
*#9998*862# -> Vocoder Reg - Normal, Earphone or carkit can be selected
*#9998*872# -> Diag
*#9998*947# -> Reset On Fatal Error
Reduced: 99% of original size [ 514 x 40 ] - Click to view full image
> All codes for samsung mobiles.......[check this out...] kashem403342 Nokia Base Band 5 ( BB-5 ) 1 03-29-2010 14:54
> All codes for samsung mobiles.......[check this out...] kashem403342 Nokia Hardware & Hardware-Repair Area 1 03-29-2010 12:18
all codes for samsung D500 stew6660 Phone Unlocking Codes & Maps 0 06-14-2008 10:53
★ Are you ready to go TURBO for 3 usd ? Check this out ★ dani146 Main Sales Section 0 02-27-2008 18:25
Mobile Music Polyphonic 1.3 Crack file!!! Check this out! casperooi Nokia Multimedia 1 10-01-2003 09:31
Page generated in 0.19786 seconds with 11 queries
