Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 03-10-2013, 00:59   #211 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 13,892
Samsung Wave Bada OS Secret hack Codes
[IMG]http://4.bp.********.com/-EIbxvhP0QoY/TwVel6lFxFI/AAAAAAAAAnA/bNES8CVcDyI/s1600/samsung-wave-mobile-phone.jpg[/IMG]
1. Factory Format
*2767*3855#
Think at least 10 times before using this code as it will format your phone. It'll remove all files and settings including the internal memory storage. It'll also reinstall the phone firmware.
Note: Once you give this code, there is no way to cancel the operation unless you remove the battery from the phone.
2. Codes for Getting Detailed Information about the Phone
*#0228#
This code will reveal the detailed information about your Samsung Wave Mobile Phone.
3. Service Mode
*#197328640#
This code can be used to enter inside the Mobile Phone Service mode where You can run various tests and change settings of Mobile Phone.
4. Sim Lock or Network Lock Status
*#7465625#
This secret code is used to check the status of SIM Lock and Network lock of your Wave Mobile.
5. Firmware Version Codes
*#4986*2650468#
This code will help you to explore the below mentioned things:
SW Version, HW Version, MP, RF Cal Date, CSC Version, CSC Model Spec, FFS Version, RC2 Version
6. Some more Firmware Codes
*#1234# - SW Version and CSC Version
*#1111# - FTA SW Version
*#2222# - FTA HW Version
7. Wi-Fi and Bluetooth Test Codes
These will help you to run WIFI and Bluetooth tests on your mobile.
*#526# - Wi-Fi Manual MFG Test Mode
*#232337# - BT RF Test Mode
8. Codes to launch various Factory Tests
*#0*# - LCD test
*#0673# OR *#0289# - Melody test
*#0842# - Vibration test
*#2663# OR *#2664# - TM Command
Old 03-11-2013, 01:23   #212 (permalink)
moulnisky's Avatar
Member: 947561
Samsung Galaxy Grand i9080 hard reset
force reset Reset the device (press and hold POWER button for 8-10 seconds)
Unlock Galaxy Premier using hard reset
Samsung GT-i9080 hard reset or reset Galaxy Premier: PRESS AND HOLD VOLUME UP + Home Button + Power
Turn the phone off.
Press and hold VOLUME UP and Home(center) button
Press Power until the phone vibrate
Wait until you see the Android logo then release all the buttons.
Select Wipe data/Factory reset with VOLUME DOWN, press Power (right hand-side)
Select YES -- delete all user data with VOLUME DOWN and then press Power
After format, press Power again to reboot phone. (select reboot system now)
Alex
Old 03-24-2013, 01:13   #213 (permalink)
Member: 1889164
Originally Posted by Jrios211 View Post
[Q]What does a Samsung Hard reset really means?
[Answer] What does a hard reset really means? it means to reset your phone to the settings and features
which were accompanied from the company or at firmware update instant.
There are actually two codes you can use to reset the password and phone setting.
Below are these codes. Type them in the phone and this should solve your problem.
*2767*3855#
and
*2767*2878#
The security code will be reset to 0000.
This will allow you to format the phone easily.
Here some tutotial how unlock phone, this work on many models:
Follow those steps:
1.)*2767*3855#
2.)*7465625*638*00000000*00000000#
3.)#7465625*638*00000000#
Now your phone is unlock forever Permanent
thank u very much, may Allah increase you your knowledge and give
you ability to have more knowledge. BMMcomputers!
Old 03-27-2013, 12:22   #214 (permalink)
Member: 1906436
Simplest way to achieve hard reset is entering *2767*3855# in dialpad and hit dial! this will help definitely.
Download Free Mobile MP4 Video
Old 03-30-2013, 13:27   #215 (permalink)
Member: 1519304
Thanks Meter: 26
samsung galaxy grand hard reset
Read More Samsung Galaxy Grand i9080/i9082 ~ HOW TO HARD RESET
The Following User Says Thank You to filesupplier For This Useful Post:
Old 04-02-2013, 17:36   #216 (permalink)
Member: 1910079
Guys need help here.. my samsung e2252 is not wiping its Games Memory on FULL RESET, i
did full reset few times by *2767*3855# but after formating and restart every thing erases but games app memory still remains full.. the Hidden apps have taken
up whole 8mb space and i cant install any more apps.. How to wipe my internal games memory??
Thnx
Sent from my HTC Glacier using Tapatalk 2
Old 04-02-2013, 17:38   #217 (permalink)
Member: 1910079
up all the 8mb space and i cant install any more apps.. How to wipe my internal games memory?
The Following User Says Thank You to pakspin For This Useful Post:
Old 04-04-2013, 09:43   #218 (permalink)
Member: 1075366
how r u all
I have Samsung gt-s7560m at&t show
too many pattern attempts!
to unlock sign in with your Google account
or enter your backup pin to unlock
I need solution, thank
Old 04-04-2013, 09:58   #219 (permalink)
Member: 1907435
Android Application Development - Really Nice Info.
Old 04-04-2013, 17:21   #220 (permalink)
Member: 1264135
please help, need to sim unlock t-mobile samsung behold sgh t919.
imei: 354321/02/096820/4
s/n: R9XQA21958H
thank you very much
Old 04-13-2013, 07:56   #221 (permalink)
Member: 1834305
Sonork: VenzEzzy
Originally Posted by rea1One View Post
not all samsung work with this code
is that code work for samsung sgh t749???
please help...Thanks
The Following User Says Thank You to ericvb2005 For This Useful Post:
Old 04-17-2013, 23:17   #222 (permalink)
Member: 1918261
samsung T-mobile
Hi. Can you help with t-mobile samsung sgh- t139 imei 012404/00/5467 61/8 ?
Old 04-17-2013, 23:53   #223 (permalink)
Member: 1766567
Thanks Meter: 640
Samsung i9000 Galaxy S hard reset
Samsung GT-i9000 Galaxy S hard reset with buttons
(I tried and it works) ClockWorkMod recovery i9000 (in short: Vol UP + HOME + power ON i9000)
If not working, charge your battery fully before doing a hard reset! (and Backup )
PRESS AND HOLD VOLUME UP + Home Button (or VOLUME UP + DOWN)
Keep pressing these 2 buttons + press Power button for 2-3 Seconds
Release only power button, but KEEP pressing Volume up + Home Buttons (or VOL UP + DOWN)
With Volume down select wipe data/factory reset (3rd) > Press Power (or HOME)
Some say in US hardware/phone with EU firnmware version has changed VOLUME UP to VOLUME DOWN key. Try that trick too and leave comment below.
i9000 unlock forgotten lock pattern
(VOLUME UP + HOME + POWER buttons) or (VOL UP + DOWN + POWER)
OR
Your Samsung i9000 device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your
device is frozen and unresponsive, press and hold for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select
Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything.
OR
1. Turn off the i9000 phone or take out the battery and reinsert it.
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 master reset
Old 04-17-2013, 23:54   #224 (permalink)
Member: 1766567
Thanks Meter: 640
Samsung Fascinate Android hard reset
Samsung Fascinate hard reset
1. Turn the phone off. If the Fascinate frozen, take out the battery and reinsert it.
2. Press and hold the Volume Down + VOLUME UP + Power buttons.
3. Release the Power button at SAMSUNG logo but keep pressing both VOLUME UP and DOWN.
4. Select wipe data / factory reset using the VOLUME DOWN button.
5. Press the HOME button to confirm hard reset.
Select Volume UP to hard reset Samsung Fascinate.
or
6. Select RESTART with VOLUME UP/DOWN, then HOME to Samsung Fascinate.
OR
Use this method to hard reset your Samsung Fascinate Android phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Add to gcceleghg's Reputation Report Post Edit/Delete Message
Old 04-17-2013, 23:54   #225 (permalink)
Member: 1766567
Thanks Meter: 640
Samsung Captivate SGH-i897 hard reset
Samsung Captivate SGH-i897 Factory data reset
From this menu you can reset your phone and sound settings to the factory default settings.
1. From the Home screen, touch ? Settings ? Privacy.
2. Touch Factory data reset, enter your password, then select Yes to confirm.
The phone resets to the factory default settings automatically and when finished displays the Home screen.
Warning!: Performing a Factory data reset will erase all data from your phone, including your Google account, system and application
data and settings, and downloaded applications. It will not erase current system software and bundled applications or files on your
SD card such as music or photos.
Samsung Captivate SGH-i897 Android System Recovery
Android System Recovery is used for Google updates but the average user will never need to perform a system recovery.
Note: If you entered this menu by mistake, use the Volume Up/Down keys to select reboot system now, then press the Power key. Your phone will then continue to boot up.
To enter the i897 Android System Recovery mode, follow these steps:
1. With the phone turned off, press the Power key and Volume Up/Down keys at the same time until the phone switches on.
2. Once the AT&T logo appears, release the Power key while continuing to press the Volume Up/Down keys.
3. Continue to press the Volume Up/Down keys for at least 8 seconds, until Recovery mode is launched and the Android
System Recovery screen is displayed.
4. Release the Volume Up/Down keys.
5. The following options are available:
?reboot system now: this option turns on your phone.
?reinstall packages: this option allows you to apply updates to your phone.
?delete all user data: deletes all data from the phone.
?delete cache data: allows you to delete all cache data such as log files.
6. Use the Volume Up/Down keys to scroll up or down, then use the Power key to make a selection.
All HTC & Other PDA Mobile Hard Reset Codes rajinder1978 HTC & PDA WM( With Touchscreen) 2 01-07-2016 13:14
All HTC & Other PDA Mobile Hard Reset Codes rajinder1978 HTC & Smartphones ( WM Without Touch) 4 11-10-2013 19:09
ALL in 1 PDA HARD RESET CODE.... pavi HTC & Smartphones ( WM Without Touch) 18 01-19-2009 10:52
ALL in 1 PDA HARD RESET CODE collections VODAFONES HTC & PDA WM( With Touchscreen) 0 12-30-2008 07:25
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.45089 seconds with 8 queries
