Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
06-28-2010, 21:47 | #3 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Lost in this Field Age: 39
Member: 154513 Status: Offline Thanks Meter: 160 | Why not publically bro. Samsung Omnia tips – Hard Reset Option 1 Software Hard Reset: Samsung Omnia On your Samsung Omnia, go to Settings/System/Hard Reset Hard Reset options will appear on the screen for a.Main Memory – Reset b.My Storage – Reset c.Storage Card – Format A pop up will ask for confirmation & user is to enter "XXXX" to proceed. i900 to use 1234 i910 to use last 4 digits of your mobile number The phone resets, lingers on the Samsung logo for a bit then the familiar Windows mobile device start up screen, which takes you through the start up process if you tap the screen to set up… You may have seen this when booting up your phone initially Alignment Set date/time Password Samsung Omnia tips – Hard Reset Option 2 Hard Reset using the hard keys: 1.Press soft reset hole beside the power button. 2.Press Call and Cancel Button together when you see the Samsung Omnia on the screen. 3.Reset Screen appear with "Are you sure you want to format? Format or Cancel". This hard reset does not erase the 8/16GB memory. To reset everything, use the software hard reset > Settings/System/Hard Reset. There is also option to format the storage card. A trick to use for Option 2 – by asctony 1. place Samsung omnia on a flat surface 2. use 2 fingers to press and hold on the CALL and END CALL buttons 3. use stylus to soft reset phone Samsung Omnia tips – Hard Reset Option 3 Hard Reset by dialing code: Use your Omnia dialing pad & key in *2767*3855# – doing this will hard reset without warning, it will also erase your 8GB/16GB internal memory |
The Following User Says Thank You to .::Gsm Killer::. For This Useful Post: |
06-28-2010, 21:57 | #4 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: CAIRO _ @ _ 112 _ -= EMERGENCY ROOM =- Age: 48
Member: 86655 Status: Offline Thanks Meter: 385 | Quote:
if i am sure i will put it lick this one check here by the way your post not for b7330 it is for old omnia | |
11-16-2010, 13:20 | #5 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Holland China Brazil Age: 43
Member: 88016 Status: Offline Thanks Meter: 320 | i am sorry you all wrong. The right way to hard reset this phone is press F key then power button it will ask master clear then press 1 and then press Y Now it will perform hard reset. enjoy |
The Following 15 Users Say Thank You to Kashif Khan For This Useful Post: |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
3110 Need to Unlock & Reset | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-22-2001 08:35 |
how can you reset the life timer without using a data cable for a 5125 TDMA phone? | PiNoY_bOy204 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-23-2001 12:46 |
HOW TO RESET SECURITY CODE IN NOKIA 6210 | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-26-2001 05:33 |
5190 patial flashes - why are they so hard to find? | Bads | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 04-14-2001 03:18 |
